Old 02-14-2019, 10:53 PM   #1
Flagstaff Entertainment Center detached from slide-out wall
Entertainment Center has detached from slide-out wall in Flagstaff travel trailer. Anyone with same problem? How did you fix it?
Lauraalfa is offline   Reply With Quote
Old 02-23-2019, 03:30 PM   #2
Failure is my business
2Evil4U's Avatar
Like, the entire corner cabinet with the TV and fireplace is loose from the wall? Haven't had that issue. If you pull the fireplace you may be able to see how it's attached. Also may be able to get a little access from the storage door on the outside. Don't use too long screws when reattaching or you could poke through the outer wall.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 278,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 78
2Evil4U is offline   Reply With Quote
flagstaff, slide, entertainment
