Old 06-03-2018, 04:07 PM   #1
mudman2's Avatar
Folding table
Hi everyone
I have a flagstaff 25 bds 2019. I was able to get the table down for traveling and canít figure out how to get it back up. Weíre on our 1st trip and this seems to be the issue so far.
Fingers crossed.
Thank you
2019 microlite 25bds
2015 tundra
mudman2 is offline   Reply With Quote
Old 06-03-2018, 04:20 PM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
It's only a crap shot, but feel or look under the table if there is a latch that keeps it locked in the low position.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 06-03-2018, 04:29 PM   #3
mudman2's Avatar
I turned it upside down and rotated 4 times. Iím sure itís a simple procedure but when your looking at 70 it makes u wonder. Thanks for the try
2015 tundra
Old 06-03-2018, 04:51 PM   #4
GalsofEscape's Avatar
if you have the same table that I have in my Flagstaff hybrid - my table swings out and then up into place. I usually place my feet on the table stand feet to keep them stationary as I swing the table top into place (it is a push the table top out then pull up into place). There should be a yellow capped locking mechanism under the table - the leg that the lock is on is the side that the table swings away from. The lock has to be released to lower the table.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 06-03-2018, 05:02 PM   #5
Kasual Kamper
If it's like ours, it's a yellow plastic latch that needs to be pressed and swung sideways. I have to rack my brain to remember every time I've got to open it because it's the craziest design I've ever seen.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 06-03-2018, 05:58 PM   #6
mudman2's Avatar
No go. But thanks for the try😀
2015 tundra
Old 06-03-2018, 08:06 PM   #7
mudman2's Avatar
Ok I figured it out. By pulling the lower frame away from top in the length of table,by some magical occurrence it rose up.
Thanks to all that gave it some thought.
Definitely a wired setup.
2015 tundra
Old 06-04-2018, 07:58 PM   #8
I was looking at the bottom of mine as I had to make a repair and noticed it had been signed by a Silvia, anyone else notice someoneís name on their table???
Ramrod79 is offline   Reply With Quote
Old 08-12-2018, 02:41 PM   #9
WoodLark-SC's Avatar
At least mudman2 was able to get the table lowered; I haven't even been able to do that. I see the little latch with the yellow button, but it isn't latched to anything. I have tried pushing/pulling in every direction I can think of (in 3 dimensions at least), and nothing happens.
There are two screws holding what looks like the reverse of the latch with the yellow button directly to the left of the yellow button latch. Is it what it is supposed to latch to? If that is the case, my table must be made wrong because there is no way the "yellow button" latch can reach the other part.
Why would anyone design something this difficult?
2013 Ram 1500 CC 4WD
2019 Rockwood 2503s
WoodLark-SC is offline   Reply With Quote
Old 08-12-2018, 02:56 PM   #10
jeff64's Avatar
If it's the same as mine.wd40 the pivot points 1st. From the rest position, lift the front of the table about 45 degrees, slide yellow button to side and lower legs and lock. Rotate table up and onto legs. To lower, slide yellow button1 ,pull table towards you. As it starts to collapse, push toward wall and guide to place on bosses between bench
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 08-12-2018, 03:52 PM   #11
Jeff64, thank you! I lubricated all the joints, and I was able to "wrestle" the table into the lowered position and raise it up again. However, it is very easy to tip. It's not that the joints are "wiggly" as described in some other posts about the table, but if you put any pressure on one side of the table, it tips very easily. My wife and I have discussed it, and we are going to take it out of the trailer, store it, and buy two smaller "personal" tables as others have done. We have no need for the extra bed as there are just the two of us with two cats and two dogs. so that won't be any loss.
2019 Rockwood 2503s
Old 08-12-2018, 06:28 PM   #12
We just got back from our first outing in our trailer and I wrestled with the table as well. I just found that I think helps to show the direction to push/pull in.
jacqui583 is offline   Reply With Quote
Old 08-14-2018, 08:06 AM   #13
mudman2's Avatar
Thanks for that video. I was wondering whether Iíd remember what I did to raise and lower it.
2015 tundra
