Old 10-10-2018, 09:48 AM   #1
Forest River Micro Lite 21DS Winterizing
I know you are supposed to bypass the hot water tank when winterizing, but don't know where the bypass is located. Any help will be appreciated.
muollot is offline   Reply With Quote
Old 10-10-2018, 10:03 AM   #2
It's the valve in between the hot and cold lines when looking at the back of the water heater. Open that valve and shut the hot and cold lines and the water heater is now bypassed. It should look similar to this. Hope that helps.
WFD473 is offline   Reply With Quote
Old 10-10-2018, 10:52 AM   #3
In case you're asking where in the sense of physical location in the trailer: I don't know the year of your 21DS, but assuming it's recent, the bypass valves are located behind the left panel below the refrigerator. The panel has three hinges, 2 on one side and 1 on the other. Remove the screws from the side with only 1 hinge and the panel will swing open reveling the back of the water heater and the bypass valves.
2018 Flagstaff Micro Light 21DS
2006 Ford F150
bergy is offline   Reply With Quote
Old 10-12-2018, 02:54 PM   #4
Thanks for the info. Will check on it and see if I got it.
Old 10-13-2018, 01:18 PM   #5
I have the front kitchen so it may not be the same. On mine, on the passenger side at the back there is a door. Unlock and open and you will see a small cubby hole with a "privacy" panel. Remove that panel and you will have access to the water filter, the value to shut off the water and turn on the antifreeze and the values to shut off water flow to and from the water heater and the bypass value.
Jim Prohs
Flagstaff Micro Lite FXS Dodge Ram 2500 '08
The Road goes ever on and on ...Until it joins some larger way ...Where many paths and errands meet ...And whither then? ...I cannot say. Tolkien
Jim Prohs is offline   Reply With Quote
Old 10-13-2018, 02:38 PM   #6
Micro Lite 21 DS
DW & I have a 2015 21DS and the Heater is on the Drivers side front in the through storage to the Left when standing at the Drivers side hatch. There is a panel on mine that Has 3 Square drive screws holding it in place. Remove the screws and you'll see the valves!
SecurityRich is offline   Reply With Quote
Old 10-22-2018, 02:56 PM   #7
Water heater drain plug
Can anyone tell me where on a 2018 micro lite 21ds the water heater drain plug is located?
Old 10-22-2018, 03:12 PM   #8
It's on the front of the water heater.
If you have a Suburban tank type water heater, then these threads may help:
Suburban's electric switch and much more
Suburban Water Heater Video Guides
The Suburban brand uses the anode rod as the drain plug as per the pic below:
If you have an Atwood brand tank type water heater, then the drain plug is a nylon/plastic plug, as per this pic below"
Iwritecode is offline   Reply With Quote
Old 10-22-2018, 04:07 PM   #9
Kasual Kamper
To me, that looks wrong! Shouldn't the top and bottom valves be perpendicular to the line? The way you're picturing it, the lines going into and out of the tank are open.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 10-22-2018, 04:23 PM   #10
You are correct. I was just showing a standard picture of the back of a water heater and plumbing for reference.
forest river, lite, winter
