Old 09-19-2010, 04:51 PM   #11
Iggy's Avatar
Originally Posted by great white View Post
My 2011 26RLSS flagstaff came with a 7 year warranty on the roof. Original owner only.
Now you do understand that is a warranty for the actual roof material only. If you do not do maintenance on the seams and around hardware and you have a water leak into the trailer that is another story.
Old 09-19-2010, 06:34 PM   #12
great white: the roof on these trailers is garanteed for 12 years and not 7 years according to the litterature.
capucine is offline   Reply With Quote
Old 09-19-2010, 08:39 PM   #13
great white's Avatar
Yup.
I'll have to check my paperwork.
great white is offline   Reply With Quote
Old 10-14-2010, 07:26 PM   #14
If you read the warranty on this roof it is quite deceiving. The warranty is pro rated and after a short period it is next to nothing. Read the sheet that came with the bundle of products included in the pouch. I looked at my new trailer roof and it looks well done. They tell you to make sure that you wash it every season with the proper cleaner.
Old 06-27-2014, 06:22 PM   #15
What is the best maintenance procedure for the TPO roofs and any recommended products?
jclark6 is offline   Reply With Quote
Old 06-27-2014, 06:32 PM   #16
Herk7769's Avatar
100% correct. The warranty is on the material.
I believe if the roof does leak and cause damage, you "may" be able to claim against your homeowners insurance. Check your policy on "outbuildings."
HAM CALLSIGN - KC3FFW
Old 08-28-2014, 05:28 PM   #17
I have recently purchased a 2011 Flagstaff V-Lite. I am trying to determine if there is a sealant/ protectant for the roof. I am under the impression I should only clean it. Camping World said to use Dicor twice a year. This is what is on the Forrest River site FAQ's Q-What should I use to coat my rubber roof?
Nothing! The only maintenance to the rubber roof itself is washing it a few times a year. Most standard household detergents are appropriate (avoid petroleum based solvents, harsh abrasives or citrus based products) to clean with warm water. Keep debris cleared to help avoid stains.
Any help would be appreciated
Old 08-28-2014, 05:45 PM   #18
jtstromsburg's Avatar
You are correct in a good washing is best. The dicor is a self leveling (or non self leveling for sidewall applications) caulking that you use to touch up or recaulk joints and seams. Around vents, etc. Some time once or twice a year looking carefully over your roof and touching up the sealant is one of the best cheap investments you'll make in the life of your camper.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
flagstaff
