Old 05-27-2014, 07:35 PM   #21
BradinOhio's Avatar
That does not look good at all. Please continue to keep us updated.
Brad, Sandy, Amber (shephard), Niko (shiba inu RIP little buddy)
'12 F-150 XLT SuperCrew 4x4 Ecoboost with MaxTow
'12 Flagstaff V-Lite 30WRKSS
BradinOhio is offline   Reply With Quote
Old 05-28-2014, 09:25 AM   #22
Here is a picture of the fix. The the metal gusset and faceplate. The faceplate is 1/4 steelon the outside of the 6" frame rail did this on both sides of the trailer. This is where the Aframe is stack on the frame rail.
Sent from my XT907 using Forest River Forums mobile app
bunnell is offline   Reply With Quote
Old 05-28-2014, 09:27 AM   #23
My fix.
Old 05-28-2014, 09:38 AM   #24
So you fixed it. How about answering the questions asked? These posts are also a learning experience for the rest of us too. Share all the information then the fix makes more sense as a result.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 05-28-2014, 03:33 PM   #25
Timex's Avatar
From what I could tell from the pic, looks like the cracks were filled in and painted over. That won't solve the problem. Something caused those cracks and if he doesn't find the root of the problem, he will soon have a bigger problem.
Just my 2$.
I'm interested because I have a 2012 VLite. Guess we'll never know, huh?
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 05-28-2014, 04:07 PM   #26
polymark's Avatar
That will likely fix the current situation but you still need to find the root cause if the incident. Fixing it is great but if II don't figure out what caused it it will happen again in a different area of the frame.
I suggest taking the unit to the weigh scales and get a weight of you tow vehicle wi and with out the trailer. Take note of all the individual axel weights. Your tow vehicle weight with out the trailer is important to show that you have the proper tongue weight. On any "Lite" trailer proper weight and ballance is important. You also want to ensure that you so not exceed your recommended GVW of the trailer.
polymark is offline   Reply With Quote
Old 05-28-2014, 07:07 PM   #27
Just my 2$.
the frame
the 6" beam has a 1/4" thick steel plate welded over the crack. the plate is 6X18.
Old 05-28-2014, 07:12 PM   #28
polymark's Avatar
The 2014 has an 8" beam and the factory lists the payload about 1835 lbs and a tongue weight of about 900 lbs. do you know what they have for specs on the yours?
Old 05-28-2014, 07:13 PM   #29
the frame
I think the question is: Were the cracks welded up on both sides or were the plates just added?
Old 05-29-2014, 06:45 AM   #30
All the cracks where welded and then the plate put over the the top of the cracks. The plate was then welded in place.
2012, frame, v-lite
