06-13-2014, 05:51 PM
Fresh Water Tank
This is our first trip out and there is no water coming out if the faucets. I can hear it gurgling but not a drop . Any help is greatly appreciated
06-13-2014, 05:54 PM
Water heater bypass valve, outside showerhead button, loose fitting near the water pump.
06-13-2014, 05:57 PM
Clueless I don't know what you're talking about
06-13-2014, 06:02 PM
Are you on city water or fresh water tank? On tank make sure your water pump is on and make sure there is enough water in it to produce the required pressure. My fist time out I put some water in my tank and by time the system pressurized there was not enough water to maintain pressure. If you have a whole house filter make sure water has made it that far.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
If you have an outside shower on the side of the head is a button make sure it is open.
Do you know where your water pump and water heater is?
Do you have a factory water filter and is the water tank full?
06-13-2014, 07:48 PM
Like Ford Idaho said...check your water heater bypass valves an your water pump valve. It takes time to clear out the air.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
06-13-2014, 07:51 PM
Thanks folks! I called the place we bought it and they walked us through it! We finally have water! The first few times out are sometimes not fun and then you sit around and laugh about it when you're more experienced with the unit!!
06-13-2014, 07:52 PM
The wh tank may be filling it'll fill first before any water comes to taps.
TURBS
"Sabre owners united"
06-13-2014, 07:59 PM
Would you mind posting what the problem was so others might benefit?
06-13-2014, 08:01 PM
Best shake down cruise site is your front yard. We still have a few laughs. Camped at the CG. Brought the bowls and the milk...forgot the cereal. Brought the buns, forgot the burgers. Another time we brought the buns, cheese and burgers...forgot the ketchup, mustard and relish. Yet another time the wife thought I packed the food and I thought she packed the food. McDonald's run later. Oh there is laughter. We still laugh. Brought all the breakfast stuff, eggs, bacon, sausage, everything. Honey where's the plates? Oops. WRITE IT DOWN!!
Chuck and Joanne
06-13-2014, 08:02 PM
Drive way camping Is awesome!
TURBS
06-13-2014, 08:05 PM
To fix my water issue I had to go under the camper storage unit where the water filter was. There is a black switch that I had to turn and everything worked well!! I don't know if I could have done it without the help of a service tech! I will know what to do next time, except I'm not going to turn it back so it should work !!
06-13-2014, 08:09 PM
There has been several threads here about water. I learned when we take a walk around the CG to turn the water off. Check my conversation about my water filter canister failure. Luckily I was standing a lot away.
Chuck and Joanne
06-13-2014, 08:14 PM
Tuesday morning in the KOA I was in the spigot blew out of the plastic water line two spaces behind us, it was a nice fountain for about ten min till the grounds keeper got the water main turned off.
06-13-2014, 08:17 PM
Always good to shut off the water. Bette safe than sorry. I was lucky.
Chuck and Joanne
06-13-2014, 08:23 PM
Koa was luck that the guy next to the empty space was outside having a smoke, he walked to the office and told the guy what was going on.
I was outside with the dog and notice the commotion, hilarity ensued.
06-15-2014, 07:18 PM
The dreaded gurgle
I had a sort of similar experience this weekend. First time using the fresh water tank. Our one previous trip we used water hookup.
Tank full, pump on....no water, heater would not fill. Bypass valves all correct. Long story short, I noticed a valve on the backside of the line going to the electric pump (after 10 minutes of head scratching) Hard to see the darn thing. Turned it on and all was well.
My old trailer did not require this and I assume I should turn it back when I next go to a water site.
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
06-16-2014, 08:02 AM
I think we had the same issue . I tuned this little black valve and all was well. I wouldn't have known what to do but called a helpful technician from CW
06-16-2014, 04:26 PM
TURBS
Not possible where I live, well possible but a pita have to get a permit and then not for more that a few days.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
