Old 05-18-2018, 07:35 AM   #1
OswegoLion's Avatar
Furnace not giving off heat!!
Needed furnace this morning! Turned it on! I heard it kick in, fan was running no heat coming on! Not sure where to check or get to furnace! Model 8528 IKWS!
OswegoLion is offline   Reply With Quote
Old 05-18-2018, 07:39 AM   #2
SeaDog's Avatar
An easy check is to go outside to the furnace cover and see if there is any hot exhaust coming out of it, if not its only the fan running. check you propane tanks make sure you are not on an empty tank.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 05-18-2018, 10:46 AM   #3
Do other LP appliances work OK?
Is the battery sufficiently charged?
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 05-18-2018, 10:46 AM   #4
Did you bleed the air out of your propane lines? If not, turn on a couple of burners on your stove top to do so and your furnace should light once the air is forced out of the gas lines. I do this before every trip to ensure that my fridge, furnace, and hot water heater light.
Skyliner is offline   Reply With Quote
Old 05-18-2018, 01:27 PM   #5
OswegoLion's Avatar
Propane not on empty!! Gas stove is working!! Turned on all. 3 burners!!! So......
Old 05-18-2018, 01:29 PM   #6
fonzie's Avatar
Are you hook up to shore power? Battery needs to have a good charge for the furnace motor to turn fast enough to activate sail switch and then gas valve.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-18-2018, 01:32 PM   #7
OswegoLion's Avatar
Yes I am hooked up to shore power!!!
Old 05-18-2018, 01:34 PM   #8
When it kicks on... do you hear it trying to ignight? (sparking noise)
You may have to listen out by the exhaust. (have someone else turn it on)
Old 05-18-2018, 05:12 PM   #9
Send a message via MSN to Tiggerdad
Had an issue with mine last year. Could hear the fan turn on, igniter would click and then hear the roar of a flame for 1-2 seconds, flame would go out then igniter would click again, hear roar of flame and then shut down again. Fan would continue to run. After third time the system locked itself down. Turned thermostat off and then back on to reset.
Took it apart and everything was clean. put it back together and same thing. Took apart again and I found a tiny wisp of a spider web that would float in the air when fan was running. Cleaned the spider web and all was well. Look very CAREFULLY for something like that, Although I overlooked the spider web the first time it take almost nothing to cause the flame to go out. Good luck and let us know what you find.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 05-18-2018, 05:35 PM   #10
Had the same problem with a spider web. Blew it out with air from the outside.
RussPastuch is offline   Reply With Quote
Old 05-18-2018, 09:46 PM   #11
Had similar trouble with our propane furnace not kicking on in our 2016 Sunseeker 3010DS. We travel with a hairy dog and some of that dog hair had been drawn into the furnace. After a thorough clean out and adding a screen to prevent a reoccurrence, have had no further problems. Just a thought.
Lazy Day is offline   Reply With Quote
Old 05-18-2018, 09:50 PM   #12
SeaDog's Avatar
That is the reason I made a filter rack to hold a 16X16 filter in front of the furnace intake in the bedroom of my TT
Retired Navy
Old 05-18-2018, 10:23 PM   #13
Check for spark at igniter. Flaky rust, cobwebs, dirt can make it difficult for igniter to spark on my fridge. Good cleaning, repositioning igniter fixed the issue for me due to rust.
Old 05-19-2018, 01:08 AM   #14
Tom48's Avatar
Back to basics. If your thermostat is like mine,.
?Fan on auto?
? Click down to heat?
Temp set to temp up higher than ambient?
Tom48 is offline   Reply With Quote
Old 05-19-2018, 09:03 AM   #15
Wolverine 1945's Avatar
Could be a Bad Igniter ???
I have had to change ours @ home,,, they do not last forever,,,
especial of installer touched it with there hand !!!
Wolverine 1945 is offline   Reply With Quote
Old 05-19-2018, 11:37 AM   #16
ClementsRoc's Avatar
I am having the same exact issue this weekend! I have a troubleshooting call into the dealership. I will let you know what they tell me.
ClementsRoc is offline   Reply With Quote
Old 05-19-2018, 11:43 AM   #17
Kinda on the subject:
I had the roof replaced a while back and when we used the furnace for the first time after that the a/c fan came on too. we only used the furnace once before and I don't remember the a/c fan blowing when the furnace was used. Could the folks who replaced the roof have wired something wrong when they reinstalled the a/c unit?
oldblueroadking is offline   Reply With Quote
Old 05-19-2018, 11:50 AM   #18
fonzie's Avatar
make sure your thermostat is on "auto" instead of high and low
Fonzie
Old 05-19-2018, 01:34 PM   #19
OswegoLion's Avatar
Hi update on my problem fan goes on and I hear a couple clicks probably ignitor but it doesnít kite fan runs!! Not sure how to check on cowers?
Old 05-19-2018, 08:49 PM   #20
Hi. Mine still isnít working either but I got a few ideas from the techs at dealership. They said to run the gas powered appliances in the back of the camper (outdoor kitchen and hot water heater off gas) to pull the gas back through the lines. After the lines are full then try again. They also said to be sure to push the temp gauge on the therm all the way up to light and then put it back down.
furnace
