Old 07-13-2013, 02:29 PM   #31
I can see on the outside beneath the slideout the plastic flextube with the wire inside. Mine too is secured with a clap and runs up the wall inside an aluminum tube. Every thing seems ok at this point(although i cut and repaired the wire where it passed theough the clap since it seemed crushed. Attached the right ends. The problem seems to be somewhere between the fuse box and this exterior place. Do you think i can pull it from the outside while attaching a new wire at the end on the inside, therefore fishing a new wire. Under the slideout it runs inside the slideout rails and then i dont know where since my fiver has the exterior tank heater option and is therefor covered. Here is a pic
ID:	35250   Click image for larger version
Marsh707 is offline   Reply With Quote
Old 07-13-2013, 02:33 PM   #32
Originally Posted by OldCoot View Post
Mine had a short to the OH light in the slide and found out one of the bottom trim screws was touching it going up the wall on the outside. Wires on mine are on the bottom of the slide and go up the rear outside wall. Pulled the screw, cut it off about 1/2", rounded it, pulled the wire down and taped it and put it all back together.
Pictures?
bakken is offline   Reply With Quote
Old 07-13-2013, 02:40 PM   #33
Are they not attached to the last message? I thought i sent them, wiil try again, here goes
Old 07-13-2013, 02:48 PM   #34
Here is how mine are routed and secured. Also shows the added alum reinforcement similar to the one on the front. The first white headed screw on the bottom was the culprit on mine.
ID:	35256   Click image for larger version
ID:	35257   Click image for larger version
ID:	35258   Click image for larger version
Old 07-13-2013, 02:57 PM   #35
Coops1's Avatar
Originally Posted by Marsh707 View Post
Yes! Isolated the problem. Line leading to the livingroom slideout. Now ill have to locate the short. Thanks to all. Does anyone know how the wire leads to the slideout. I can see the wire go up the slideout exterior wall i guess the wire runs in a sub floor? Is there any kind of wire support beneath the floor such as pulley or anything else. Cqn i simply attach a new wire and fish it through the sub floor.
2 weeks ago we fished a camera wire to the back of our trailer through the under belly and and from what I seen they used wire loom stubbed into the under belly then the wires where run free air. Open up the under belly closest to your panel and go from there.
26WRB - V-Lite
Denali HD LML
Coops1 is offline   Reply With Quote
Old 07-13-2013, 03:06 PM   #36
Might want to start with the slide light fixture and replace those first. It might be at the fixture too.
Old 07-13-2013, 03:09 PM   #37
Lopks like ill have to try, since i am pretty sure the problem lies somewhere underneath. I just cut the wir wher it starts up the wall and it looks just fine . Do you remember how to open her up without to much trouble. I would never have thought they would be just hanging loose under there.
Old 07-13-2013, 03:29 PM   #38
Coops1's Avatar
The panels under there are just screwed to the frame and beams.
26WRB - V-Lite
Denali HD LML
