Old 04-19-2011, 02:03 PM   #1
Coupey's Avatar
Fuse location 8528BHSS front lights
Hi need help locating the fuse for the front lights and front locker as they have all gone off, I have checked the bulbs and they are all ok. I have looked down by the battery and there are loose fuses which are ok and I think they are for the front jacks and the two slides.
Any help of where to look would be much appreciated
thanks
Martin
Coupey is offline   Reply With Quote
Old 04-19-2011, 05:18 PM   #2
Dave_Monica's Avatar
Have you checked all the 12V fuses in the breaker/fuse panel?
It's got to be one of them.
Dave
Old 04-19-2011, 06:29 PM   #3
Herk7769's Avatar
Just had another fight with my dealer; trying to get a wiring diagram. Their story is that FR will NOT release a wiring diagram to THEM.
Why? I don't know.
Try behind the power center as well. I have 4 unmarked inline fuses back there. The pigtails of the fuse holders are ganged at the 12 volt battery connection on the power center board.
HAM CALLSIGN - KC3FFW
Old 04-24-2011, 04:13 AM   #4
Coupey's Avatar
Thanks for the info, I have checked every fuse in the main board, but no sucess, they have a red led next to each one that also indicates if a fuse has gone. I still removed every one just to be sure. I found the loose fuses by the battery, none had gone, I will contact my dealer over here in the UK on tuesday and see if they can help (which I doubt).
Old 05-19-2011, 06:37 AM   #5
Coupey's Avatar
Just a quick update on the fuse for the front lights, after much searching I eventually traced it to the AC fuse in the main board. This was only realised when the red LED decided to turn on, replaced the fuse and hey presto the front lights worked.
28bh, 8528
