Old 08-30-2018, 08:07 PM   #1
Fuse location for slideout
Good evening
My #2 slideout would not open. I closed it with no problem. Drove to RV Park. Went to open it. Nothing. No noise, no movement at all. Thinking maybe a fuse might have blown. Anyone know where I can locate fuse or maybe a different diagnosis? Thanks PS it opened normally with hand crank😎
Ct-Flagstaff is offline   Reply With Quote
Old 09-01-2018, 09:32 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place got get your questions answered. You need to provide some basic information so folks can give you some help. Make and Model of rig and slide would really help. All these rigs are different
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-01-2018, 03:03 PM   #3
Those breakers/fuses are usually near the tongue or at the frame near the front. However, as SeaDog says, giving the model of RV you have helps.
Gotta go campin!
Old 09-01-2018, 06:17 PM   #4
Found fuses
Thank you Bama I located fuses and found bad one.
Old 09-01-2018, 06:48 PM   #5
Thanks Seadog I will follow your advise. Was able to find bad fuse. ��
Old 09-01-2018, 08:02 PM   #6
bikendan's Avatar
Well, please let us know where it was, so others can benefit.
Old 09-02-2018, 08:39 AM   #7
2015 Flagstaff 27rlws 1 of 3 slide out not working>problem solved
The fuses for the 3 slide outs are located under the front right corner of the trailer within 15 inches of the battery. They are hanging down within easy view. The fuses are installed in individual water proof cases.
Old 09-02-2018, 01:39 PM   #8
It sure would be nice if the owners manual stated where fuses were located. I also had problem with slide out blowing fuses. They were where CT-Flagstaff said. I replaced my fuses the re-settable type of the same size as the original. No more blown fuses.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 09-02-2018, 02:04 PM   #9
Good idea!
Good idea. The resettables are similar to a slow-blow fuse. They won't blow on the transient startup current of a motor, but will act in time to prevent damage from a short-circuit or locked-rotor motor.
Larry
Larry-NC is offline   Reply With Quote
Old 09-02-2018, 02:57 PM   #10
I’ll keep the resettable fuses in mind if I continue to have issues. Have a box of 5 regulars for now. As far as the manual having detailed service info. Very little if any I could find. guess that’s why this forum is so popular. Safe travels
Old 09-02-2018, 04:40 PM   #11
Fuse
Great idea on resetable fuses. I can not get to the drawer I keep my spares in w/o getting slide out. thanks!
Tundra 2014 is offline   Reply With Quote
