Old 02-26-2019, 09:05 AM   #1
timmyd's Avatar
Gap above bathroom door
Just brought home our new 29RSWS. The bathroom door has about a four inch gap between it and the ceiling, and a smaller gap at the floor. I have two teenage girls that are very finicky about their privacy. I am looking for ideas on how to eliminate that gap, short of replacing the door. Has anyone used any sort of weather stripping or something at the top or bottom of the door?
timmyd is offline   Reply With Quote
Old 02-26-2019, 09:12 AM   #2
KyDan's Avatar
Hi and welcome to FRF!!
The gap is there so the bathroom exhaust fan can do it's job.
Camping in an RV does result in a little loss of privacy.
IMO, the girls need to get used to it.
Sounds travel easily inside a camper.
My advice is turn on the fan for cover noise.
Even turn on the stereo if absolutely necessary.
The door gap truly is necessary.
Without that gap- if someone has the exhaust fan on while taking a shower or using the can- tank odor will very likely be pulled up into the bathroom.
NOT GOOD!
Good luck and happy camping!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 02-26-2019, 09:17 AM   #3
The gap is for proper air flow when exhaust fan or AC is in use.
2014 Ram 1500 HEMI Lone Star Edition
2018 Coachmen Freedom Express 248RBS
2017 Harley Davidson Road Glide
Roberte52 is offline   Reply With Quote
Old 02-26-2019, 09:28 AM   #4
PPST Wannabe
kenandterry's Avatar
NOT GOOD!
What KyDan said. Thatís it, thatís all.
He made the only options there are in an RV.
Thereís nothing more to discuss here.
Just have a look at any RV units......itís an industry design to have short doors.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 02-26-2019, 10:07 AM   #5
timmyd's Avatar
Thanks all. I never thought about the airflow issue, and that makes perfect sense.
Old 02-26-2019, 10:16 AM   #6
I love it when folks give you their opinion and then tell you that's the final word on your topic, "There’s nothing more to discuss here.", ... of course there's other options, they may not suit your need, you would have to be the judge of that, but there are more options, ... we covered our bathroom door opening with a curtain, we didn't go floor to ceiling with it, but you certainly could, ... another privacy option is, we hung a shower curtain inside the glass stall, not for privacy, but to stop a leak we couldn't locate, but the extra privacy is appreciated, ...
ID:	197665   Click image for larger version
ID:	197666   Click image for larger version
fella10 is offline   Reply With Quote
Old 02-26-2019, 10:24 AM   #7
Some RV's are built with opaque bathroom doors...why I don't know except to let more light in.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 02-26-2019, 10:39 AM   #8
Install a bigger door, but vent thru the walls. Gotta have the air flow.
Oh Look ! another option.
TheWolfPaq82 is offline   Reply With Quote
Old 02-26-2019, 10:53 AM   #9
Prime Member
I have been know to put up a tent outside the camper as a changing room.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 02-26-2019, 11:11 AM   #10
bubbles's Avatar
Don't need a gap at top of door but do need the space at the bottom. The exhaust fan will pull air in from the bottom gap of the door which is sufficient air flow for all odors and such to be expelled out the overhead vent. Actually probably more efficient with less openings for fan to do its job.
bathroom, door, roo
