Old 10-13-2016, 04:20 PM   #11
Witch Doctor's Avatar
Originally Posted by lesptr View Post
Your sponge in a sandwich bag is a great idea until it's fixed properly. I'll check back for photos.
L
Sorry it took so long, but I had a long Dr. appointment today. The first picture is the new density foam I told you about in 2012 they had the same thing but you will see a plate that it sits on and behind the plate is a piece of 6" long wiper rubber screwed to the plate then screwed to the frame, it doesn't move with the slide. I think you might need the first picture. it comes in a 18" long piece. I think that the old one is better myself. hope this helps you... The one thing is that I have about 21/2" between my wall and slide your unit might only be 1" or so.... Also you can see how much bigger my foam is then the newer models they kept sending me. But I also lost that plate for some reason.
Name:	corner RV slide 001.jpg
ID:	122886   Click image for larger version
Name:	corner RV slide 002.jpg
ID:	122887   Click image for larger version
Name:	corner RV slide 005.jpg
ID:	122888   Click image for larger version
Name:	corner RV slide 006.jpg
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 10-14-2016, 12:18 PM   #12
lesptr's Avatar
Thank you for the info. I just updated my profile to show the 5er. 2017 Chaparral 334Tsik. I will crawl under it when I get back in the country next week.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
slide
