Old 05-09-2014, 09:06 AM   #1
GC
GFCI outlet
2014 Flagstaff 832IKbs
Had a power surge and now the gfi in kitchen/entryway won't reset. Has power coming into it
But 3 outlets don't work.
I'm thinking of replacing the outlet but not sure if it needs to come from rv parts or can it be purchased at Lowes/Home Depot. It has a little red light on it and says 3 pole.
Any thought are appreciated.
Gary
GC
garycarson is offline   Reply With Quote
Old 05-09-2014, 09:12 AM   #2
TURBS's Avatar
Lowes home cheapo units are preferred.
Rv units are cheap crap
TURBS
Sabre owners united!
Old 05-09-2014, 09:21 AM   #3
Herk7769's Avatar
There are circuits in the GFCI that determine if it should be allowed to pass power to the outlets and all downstream outlets. These can be damaged.
However, before you replace it, press the reset button (sometimes in red; other times in outlet color and not easily seen). If it snaps in you are good to go).
There is also a test button that should be checked/pressed monthly.
It should pop the GFCI reset button; just press it back in after the test.
Oh, I have also seen plugs that are oddly shaped that can press on the test button and cause the outlet to malfunction (not work).
HAM CALLSIGN - KC3FFW
Old 05-09-2014, 01:29 PM   #4
Slympicins's Avatar
GFCI outlet
Did you check your main breaker? When was running my two electric heaters the main would pop when something else kicked in. Seems they ran every GFI on the same breaker.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 05-09-2014, 05:22 PM   #5
GC
Replaced the GFCI and all the other outlets now work.
Fried the coffee pot, fan, blender. TV was smoking but seems to work. Will keep an eye on it for a few days along with everything else. Could have been a lot worse.
Thank you everyone.
Gary
GC
Old 05-09-2014, 05:40 PM   #6
TURBS's Avatar
Thank you everyone.
Gary
Do you have a surge suppressor?
Im not sure how a gfci can fry anything?
Maybe someone with more knowledge can explain.
TURBS
Old 05-09-2014, 05:50 PM   #7
VinceU's Avatar
TURBS
Sounds like GFCI was only one of six items fried at the same time. Lightning strike or power supply briefly out of control, gen set or Power Co.?
Old 05-09-2014, 06:08 PM   #8
TURBS's Avatar
Thats what I'm thinking.
TURBS
Old 05-09-2014, 06:18 PM   #9
jimh's Avatar
before u go buy another gfci, pull the old one and see how much space u have to work with. my trailer is 2002 and the reg outlets have their own cover on them so that they don't have to be installed in a box. a gfci may be the same for a trailer. i would take the existing gfci with me and compare it to the new one. u may not have enough depth in the "wall" to install another type (assuming they are different).
they usually run other outlets from the gfci. i have at least two other that are strung off the gfci. my gfci is in the kitchen and it controls the outlet in the bathroom and i believe one other.
mark the wires u disconnect from the gfci and what terminals they are attached to on the gfci. one will come from ur breaker box and the other will go to the other outlets.
jimh is offline   Reply With Quote
Old 05-09-2014, 06:39 PM   #10
VinceU's Avatar
Jim,
Post 5 he changed the outlet, like you I wondered if the outlet was deep enough, I guess it was!
