Old 02-01-2014, 07:38 PM   #11
Slympicins's Avatar
I'm feeling lucky. Sitting in the RV now watching a little TV and no more problems popped up. Changed out the Dometic 300 toilet today with the 300 with the new modification. Took 15 minutes. Hooked up everything and no leaks (ya). Re-winterize it again tomorrow. Took advantage of the one day heat wave today. Snow again Monday.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 02-17-2014, 06:08 PM   #12
I had wheel bearing issue and discovered the rear wheel grease cap was slightly larger than the front! Two trips to the parts store!
PauliJ is offline   Reply With Quote
Old 02-18-2014, 07:26 AM   #13
Herk7769's Avatar
An email to the manufacturer might have resolved this at no cost to you.
Al-Ko was quick to mail out some free center rubber plugs when mine started cracking and slinging grease.
HAM CALLSIGN - KC3FFW
Old 02-18-2014, 08:28 AM   #14
Brother Les's Avatar
I have never had the grease-able zerks on a camper before. How easy is it to take the rubber cover off and put back on with out damaging them? Sorry for the hi-jack of thread. Any suggestion on the greasing process would be helpful. My last camper I took the bearings out and hand packed them and was comfortable with that.
thank-you
Brother Les
Old 02-18-2014, 08:44 AM   #15
Herk7769's Avatar
To avoid diverting this thread; check here for what you need:
Ultra-Lube Axles and Bearings Procedures
Old 02-18-2014, 08:46 AM   #16
thank-you Herk.....
Brother Les
Old 02-18-2014, 06:20 PM   #17
Ret E-9 Anchor-clanker
donanddona's Avatar
Bearings
Don't let your grease leak out......
ID:	46451   Click image for larger version
donanddona is offline   Reply With Quote
Old 02-18-2014, 06:23 PM   #18
donanddona's Avatar
I now grease minimum three times, that twice during the regular season and one to start the season. Several times I have found grease caps rolling inside the center spinner.
trailer
