Old 04-08-2016, 07:22 AM   #1
OswegoLion's Avatar
Grease for Fifth wheel hitch and pin box?
What do you use for lubricant? Any help would be appreciated. Thanks
OswegoLion is offline   Reply With Quote
Old 04-08-2016, 07:32 AM   #2
This http://www.amazon.com/Kwikee-Product...e+spray+grease
and also use this http://www.amazon.com/Reese-Towpower...heel+lube+disc
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=40
Electra glide is offline   Reply With Quote
Old 04-08-2016, 07:38 AM   #3
Fluid Film
Berkebile Spray Red Grease
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 04-08-2016, 07:48 AM   #4
OswegoLion's Avatar
White grease work?
Old 04-08-2016, 07:52 AM   #5
Justice12t's Avatar
Good question. For the others...I have the nylon disc, do I need to use some sort of lube with that also?
2016 Prime Time Crusader 294RLT
2018 RAM 2500 Laramie CTD, CC, 4x4...ect
2017 Days Camped - 14
2018 Days Camped - 15
2019 Days Camped - 34
Justice12t is offline   Reply With Quote
Old 04-08-2016, 07:53 AM   #6
No, the discs are designed to be used 'dry'
The material has lubricity built into it.
Old 04-08-2016, 07:54 AM   #7
Gold Miner At Heart
Papa-t's Avatar
I use the plastic disk on the 5er hitch so no greese is needed there. As far as the Fifth wheel hitch itself. I think as long as you keep it lightly greased it will be fine. I take the head off and clean all the old Greece and dirt off each season and lightly regreese.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
Papa-t is offline   Reply With Quote
Old 04-08-2016, 07:55 AM   #8
Honestly with the Nylon disk I never noticed a need to use the grease. Fluid Film would be good also. I've used that stuff on my shovels and snow blower and the underside of my old F250.
2016 Vengeance 320A
Old 04-08-2016, 08:01 AM   #9
dieselguy's Avatar
I use the nylon disc as well ... the main purpose of the disk is to get away from lubing the pin plate and hitch head surface, so like mentioned earlier there is no need to lube it. I do use lithium grease on the moving parts in the hitch head itself.
dieselguy is offline   Reply With Quote
Old 04-08-2016, 08:04 AM   #10
clr
I use the nylon disc also and so I do not grease the 5th wheel disk. Just make sure the hitch disk and the 5th wheel disk is clean prior to hooking up. On long pulls I do put a dab of grease on the King Pin also. I have pulled without the King Pin being greased also and had no problems. But my old dad told me if it is metal to metal it needs to be lubricated.
clr is offline   Reply With Quote
Old 04-08-2016, 08:04 AM   #11
White grease work?
It will... but wouldn't be my first choice as it tends to wash off easily.
Old 04-08-2016, 08:07 AM   #12
OswegoLion's Avatar
Type of regular grease available?
Old 04-08-2016, 08:13 AM   #13
Not sure what you are asking?
We've given suggestions.
Heck, even Vaseline will work if you are diligent about keeping it clean and lubricated.
fifth wheel, hitch, wheel
