Old 06-18-2017, 06:10 PM   #21
(Dry Huunday)
DreiHunde's Avatar
Nicely done!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 06-18-2017, 07:31 PM   #22
Too old to be too smart
SpringerPop's Avatar
Quite nice, indeed!
Don't regurgitate into your battery box, 'cause THAT will get hydrochloric acid on the aluminum!
Zinc chromate goes a long ways to prevent aluminum from feeling the effects of its environment, if that should ever become an issue at all.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 06-18-2017, 08:32 PM   #23
http://www.allbatterysalesandservice...cfm/4,573.html
325BH is offline   Reply With Quote
Old 06-18-2017, 09:20 PM   #24
great white's Avatar
Pop
I'm actually thinking of doing the interior in bedliner. I'm in aviation (well, almost out now) , getting some zinc chromate is no problem. I thought about it, might spray the interior with it. Boesheild works great, but not really something you want to use in an application like this and total overkill.
Nice enough, but I've only go 60 bucks into the project so far (having my own ming and access to metal shop helps!). 53 Bucks USD a piece would more than quadruple what I've already spent!
LOL!
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 06-19-2017, 12:49 PM   #25
Mountainmanbob's Avatar
I was also looking for a double battery box and found the perfect one at a battery store for around 70 bucks heavy duty plastic perfect.
Mountainmanbob is offline   Reply With Quote
Old 06-19-2017, 02:38 PM   #26
Nice job.
2019 Ram 3500 DRW HO Cummins, Aisin Trans and 4.10 gears.
2017 Flagstaff 8529 IKBS Classic Platinum Edition
Beauty and Beast is offline   Reply With Quote
Old 06-19-2017, 06:07 PM   #27
Summer2Go
Summer2Go's Avatar
I'm trying to figure out how to get 2 batteries on the tongue of my RV. I've been all over the internet looking for boxes. Your box looks a lot like the $300 ones! Nice job.
Summer2Go is offline   Reply With Quote
Old 06-19-2017, 07:35 PM   #28
Next project: same box with insulation=beer cooler
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 06-19-2017, 07:51 PM   #29
Need a like button. ^^
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 06-19-2017, 10:23 PM   #30
Iwannacamp's Avatar
Very well documented and well executed.
2017 Puma 297RLSS
Old 06-25-2017, 10:03 PM   #31
Got some work done today. First was an easy shower head install:
Video speaks for itself I think. Well worth the time, money and effort to bring it over from the UK.
Then I installed the Progressive Industries surge protector. My power comes in at the side rear of the trailer and there's a box/end table to hide it all in:
All wired up an attached to the floor:
All back together:
I'm going to mount the controller/display to the front of the cabinet, I just didn't have a proper drill to make the hole for the wire. I feel much better with a good surge protector installed and this ones the "Cadillac" of protectors.
I also installed the Wineguard Wingman (easy as pie) and the Wineguard Sensar Pro. I have to bring a panel cutting with me when we head back to the trailer as the Sensar Pro needs a bigger hole than the original antenna booster. Otherwise, easy install.
I also installed the Progressive Dynamics convertor with the wiz pro. It was the "upgrade" kit that slides right into the WFCO housing. Not even 10 mins to do the swap out and it will look after my golf cart batteries far better than the WFCO ever would have. Again, the "Cadillac" of convertors.
Things are coming alone nicely.
2011, battery
