Pit Boss BBQ and fire pit
I agree, the low pressure BBQ that came OEM went to EBay before we used it. Been using: Pit Boss Grills 75275 Stainless Steel Two-Burner Portable Grill.
It has 2 burners, so you can do indirect cooking on the other side.
Warning, this sucker gets hot, so keep your vigil, you need to watch out for flame ups, especially cooking lambchops, etc. But the quality is way above average. The stainless is higher grade, and the grate is really stout. I wrapped the bottom inside with foil, and just have to replace the foil about after every 5th or 6th use. Watch out for accumulated grease on the bottom inside, since the temps get to over 600 degrees F pretty fast, and ignite things.
We just use an extra 20 lb propane bottle for the BBQ, ... and/or for the firepit, if we want a campfire... our Firepit/bowl btw is a: Outland Firebowl 870 Premium Outdoor Portable Propane Gas Fire Pit with Cover & Carry Kit, 19-Inch Diameter 58,000 BTU Auto-Ignition. We put in the fake logs (Barton Fireplace Decoration Petite Ceramic Wood, Gas Fireplace Log Set, 10 Piece Set) with a few of the rocks, looks much better, although the logs are a bit on the expensive side, we love it.
