Old 01-23-2011, 08:02 PM   #1
Heat?
OK we were out in the camper this weekend. It was 21deg. and we went to bed with the heat on (suburban electronic ignition) we woke up to cold noses. We covered up the kids and tried to get the heat to come back on with no luck. Note that the camper is new to us and this was our second outing and had not gotten a back up heater yet. The heater would blow cold air only. We had plenty of propane and we were hooked to electricity. When it would blow cold air we smelt propane coming thru the vent and decided to stop messing with it. We stayed in hotel the next nite. Went to load up and I tried it again. Same results. Drive 5 hours back home. I tried it again and it worked. I am really frustrated. What could be the problem? ? Hope I did not get a lemon.
Kperk
kperk is offline   Reply With Quote
Old 01-23-2011, 10:45 PM   #2
Sketchy description of the problem, and may be hard to duplicate. When a propane appliance doesn't work, you need to verify you have propane in the rv. I don't mean just got the tanks filled yesterday. Would the stove light, run enough hot water to make to water heater come on. You said you smelled propane, don't know anything about year or model, but did your propane detector go off? If not, it needs checking, if indeed you smelled propane. You could have had a frozen regulator, in which case, if it was warmer when you got home, it started working. You could be very low on propane. again, heat changes pressure, so if was warmer when rechecked, all might seem well. You could have a loose wire/bad connection. You could have too much stuff to keep guessing. Need to duplicate the problem. Then start with propane flow in the rest of the rv. We can help after that.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 01-24-2011, 08:06 AM   #3
Yes we had propane to the rest of the camper; the stove, oven, water heater, and refrigerator was functioning properly on the propane. The regulator was not froze. When I wrote this post it was working and then it happened again... Once it got to the set temp in the trailer which it was 25 deg. it would not come on again just blew cold air. I am taking it in today to have them look at it.
Old 01-25-2011, 09:51 AM   #4
It was a Thermostat that was going out.
Old 01-25-2011, 10:31 AM   #5
CLASS "A" Senior Member
cfsoistman's Avatar
T-Stat was bad or loose wire connection at T-Stat?
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-25-2011, 10:37 AM   #6
Service order said that the T-Stat was replaced??
Old 01-25-2011, 10:44 AM   #7
cfsoistman's Avatar
Good to hear you're back up and running.
Keep an eye out near the end of February at Walmart for deep discounted electric matress pads and blankets. We picked up Queen blankets for $20 each and King Matress Pads for $10 last year. They're good to have especially when the furnace goes out and also helps to save propane by keeping the t-stat set down at night.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
