Old 01-28-2008, 07:58 AM   #1
Heat From Lights & LEDs
Has anyone noticed the 12v 921 blubs turning dark and the white recepticles they plug into turning brown from the heat?? Is this normal? Also, has anyone played with replacing these with LED's? How did it work out??
segel10 is offline   Reply With Quote
Old 01-28-2008, 06:35 PM   #2
powerboatr's Avatar
yep they sure do get hot
i replaced the bedroom over the bed lights with leds they are not as bright but do provide enough light to see, but not read, but who reads in bed anyway ????
www.superbrightleds.com
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 02-18-2008, 12:00 AM   #3
Make sure that you have the correct wattage bulbs in the lamps.
There are several bulb types with the T5 Wedge base. These are in our 23FBS:
Range hood: 912, 12 v., 12 w., T5 wedge base
Overhead lamps and bathroom lamp: 921, 12 v., 16 w., T5 wedge base
Over-bed lamps: 158, 3 w., T3-1/4 wedge base
Clearance: 194, 5 w., T5 wedge base
You might consider going to a lower wattage bulb although we have had no problems with lens discoloration.
pduggan is offline   Reply With Quote
flagstaff
