Old 10-16-2017, 10:35 PM   #1
tonyz1's Avatar
Heat strip in air conditioner help?
We have a new 29KSWS that came with two factory installed Coleman Mach 3 air conditioners and the front air has the installed heat strip. My question is should we close the grill vents when using the heat strip and let air all go thru the ducted vents? The strip is controlled by the wall thermostat but paperwork doesn't really explain how to use it correctly and wasn't covered in our PDI so hoping for some insight from others. Thanks
Tony & Brenda
2017 Ford F-250SD 6.7 Power Stroke
2018 Flagstaff 29KSWS
Happy Camping!
tonyz1 is offline   Reply With Quote
Old 10-17-2017, 08:14 AM   #2
SeaDog's Avatar
The unit is designed to be operated in either mode thru the ducts or direct out the vents.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 10-17-2017, 09:02 AM   #3
tonyz1's Avatar
Thanks SeaDog for your reply. I was wondering about how it was designed to operate and to make sure I didn't cut air back too much and overheat something. Thanks again.
Tony & Brenda
Happy Camping!
Old 10-17-2017, 09:37 AM   #4
Steeljag's Avatar
Tony, we were able to use ours for the first recently on a trip with temps in the 40s. It seemed to work well, just noisy, and something I really did not want to listen to making coffee in the early AM.
Easy to operate by placing the digital thermostat to Heat strip and Auto ( or high / low whatever you like).
I don't see it being an issue with heat build up with the two options you listed !
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 10-17-2017, 10:11 AM   #5
tonyz1's Avatar
Thanks Steeljag. We ran it shortly last night and I agree with the noise with the air conditioner fan running constantly. Turned it off before bed and ran furnace during the night. We ran into a learning curve when running one or both airs at the same time also, how many vents to open in the bedroom to keep temp about the same throughout camper. Thanks again.
Tony & Brenda
Happy Camping!
Old 10-26-2017, 12:59 PM   #6
Rookiewood's Avatar
I have a 2018 Rockwood Signature ultra light 8311 WS with 2 AC units. The first one is 15 K BTUs and the other one (I thought it was 13.5)....
To my surprise I found the two units have the heating strips !
The question is.... do they put heating strips in AC units less than 15K BTUs, or do I have 2 15K BTUs units ....?
2016 Chevrolet Silverado 2500HD LTZ Z92
2018 Rockwood Signature Ultra Lite 8311WS
Rookiewood is offline   Reply With Quote
Old 10-26-2017, 03:11 PM   #7
SeaDog's Avatar
To the best of my knowledge the addition of emergency heating strips on heat pumps are not determined by the BTU rating of the unit. You can tell the BTU rating by reading the data plate it will be listed in BTUs or tons of AC.
Retired Navy
Old 10-26-2017, 04:11 PM   #8
Just as confused as you
Scrapper's Avatar
Just so people knows the difference.
A heat pump is just a AC that's been wired so the compressor can run in reverse when in heat pump mode. The heat pump does not work very well when the outside temperature is below 40 to 45 degrees. They will put out some heat at 35 degrees but not enough to bring the indoor temperature above 40 degrees.
A heat strip installed in a AC is just a 1500 watt heater that is similar to a portable electric heater. The strip is similar to the heat strip in the 120 volt fireplace.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 10-26-2017, 08:56 PM   #9
SeaDog's Avatar
heat pumps don't reverse the compressor it runs the same regardless of mode. The difference between a heat pump and a straight AC is the heat pump has a reversing valve that changes the flow of refrigerant.
Retired Navy
Old 02-05-2018, 07:36 PM   #10
mac8's Avatar
Heat strip and furnace together
If you want to add heat strip but continue to use furnace as back up to the heat strip. Would you simply divorce furnace from ac and Heat strip thermostat and install thermostat for furnace only and set to come on at certain temperature regardless of heat strip setting. Probably not a very clear question, but hopefully y'all can help.
mac8 is offline   Reply With Quote
air conditioner
