Old 03-31-2017, 08:54 AM   #1
Hello
we have a 2015 flagstaff classic ultra lite 829IKBS 35 ft. the holes they cut for wiring and pluming were left not insulated around them and lots of cold gets in , will be insulating those up later . this is a 2015 left over that we bought in august of 2016
maineguy53 is offline   Reply With Quote
Old 03-31-2017, 11:47 AM   #2
You will find lots of places where they cut a hole for plumbing or wiring where the hole is WAY larger than what goes through it. If your unit has the enclosed plastic underbelly, you'll be totally amazed at the things you'll find if you drop it and look in there!
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 03-31-2017, 11:55 AM   #3
dbledan's Avatar
Use either the critter foam or if no electrical put steel wool in the hole first to keep mice out then add spray foam. Don't use the steel wool in electrical though because if there is a short it could cause a fire.
dbledan is offline   Reply With Quote
Old 03-31-2017, 02:08 PM   #4
thanks yes we do have the plastic underbelly and think we have a critter
Old 03-31-2017, 02:09 PM   #5
Thank you we will use the foam and steel wool
Old 03-31-2017, 03:07 PM   #6
I would suggest brass wool over steel wool. Steel wool will rust, it's steel. Brass wool won't. You can find it at Walmart where they sell kitchen sponges etc.
Old 04-01-2017, 04:58 AM   #7
I will get the brass wool thank you
