Old 05-24-2015, 08:21 PM   #11
Herk7769's Avatar
The stabilizers should have two fuses; one fast blow in the power panel and a lower rated automatic reset one right at the switch. Corrosion at any of the terminals can cause failure to operate.
Name:	Hidden circuit protection rear stabilizers.jpg
ID:	77931   Click image for larger version
Name:	Lower CB Panel.jpg
HAM CALLSIGN - KC3FFW
Old 05-24-2015, 08:46 PM   #12
Timex's Avatar
Originally Posted by fonzie View Post
Look for a 20 or 30 amp fuse in your distribution panel label PSJ as last fuse in photo, take it out and check visually if blown, might have blown when your retracted the rear stabilizers and hit the stop and why front one not working.........
Hey Fonz, either some of your fuses are upside down or you have some strange amp fuses.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 05-26-2015, 05:17 PM   #13
THANKS!!!! All your feedback and suggestions were great and much appreciated! I went back to storage yesterday and was able to get the jacks working. I do have a reset breaker going into the battery but that didn't do the trick. So I checked the rear stabilizers for movement and they did not work either. So I must have blew the fuse after raising them. I found the fuse inside in the main breaker/fuse box. I actually looked there the first day but the fuse was not lit up nor was it labeled very well. Needless to say, I found which fuse it was and replaced it.... and viola... all the jacks are back working. I'm also the proud new owner of a large box of every size fuse I saw in the box and 30amp ones as well for my electric tongue jack. Thanks again!
2015 Flagstaff 29FBSS
Camping: 2016 - 22 days so far and lots more scheduled; 2015 - 40 Days, 2014 - 20 days
Aggie_90 is offline   Reply With Quote
Old 05-26-2015, 05:25 PM   #14
You should get an auto-reset for the jacks.
Old 05-26-2015, 05:34 PM   #15
Ford Idaho's Avatar
Old 06-23-2015, 12:09 PM   #16
I have a new 2015 29FBSS with Lippert electric stabilizers on the rear and front. The ones on the back worked great today, but the ones on the front didn't even make a sound when I tried to raise them. Any ideas? Do they have a fuse that could be blown? If so, where is it? TIA!
Just unplug your power cord and then flip the battery switch to off. This will cut all power and then flip back on your battery. Your jack should now work fine. Mine does that sometimes.
gcrouch is offline   Reply With Quote
Old 06-27-2015, 09:57 PM   #17
lube the screws
also
riverrat958 is offline   Reply With Quote
Old 06-29-2015, 09:26 AM   #18
Old Coot..... This is a stupid question I'm sure but when you refer to an auto-reset do you mean a resettable breaker or something else? I'm clueless when it comes to the electrical part of my RV but since my new one has so many electrical items I'm thinking its time I learn :-/. Just bought a new Progressive Portable Surge Protector.... Can't wait to try it out :-)
Old 06-29-2015, 09:31 AM   #19
B and B's Avatar
Herk, sad part about the stab jacks is to get at that breaker you have to rip the cabinet apart. Wish they made a access hatch for it.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-29-2015, 09:50 AM   #20
AKA: 'tiredTeacher
awellis3's Avatar
It replaces the existing fuse in the trailers fuse panel. Go here to se what thy look like. Littelfuse UCB10 12 Volt 10 Amp Auto Reset Universal Automotive Circuit Breaker | eBay
I got mine at NAPA. They're available in various amperages, of course
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
electric
