Old 03-10-2013, 02:52 PM   #1
Help...finding slide fuse
On the road, and apparently the fuse has a blown for the slide on my 28RLSS Flagstaff fiver.
Found a 30 amp in-line fuse near the battery, but it visually appears to be in good shape and it's the only one I can find near the battery.
Any one know where I can find the rascal?
TeeCee is offline   Reply With Quote
Old 03-10-2013, 03:02 PM   #2
lindy's Avatar
the other fuse is most likely located in the circut breaker box for the camper. There'll be a row of spade type fuses off to the side of the circut breakers. There might even be red indicator lights that light up when the fuze beside the light is blown.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 03-10-2013, 03:53 PM   #3
Wish so...but, alas, not so. Thanks though.
Old 03-10-2013, 04:09 PM   #4
caper's Avatar
Have you checked the fuse with an ohm meter or just do a visual check?
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-10-2013, 04:27 PM   #5
No meter on board...
It doesn't look like I can just disconnect it, as it has some type of connectors that I'm a little concerned about breaking the contact in case it's the landing gear fuse.
Any idea how I can safely remove it?
Maybe I'm over thinking it, but want feel OK about it before I pull the connectors off the ends of the fuse. And is it possible that it takes a non-standard 30 amp fuse?
Thought? Thanks.
Old 03-10-2013, 04:37 PM   #6
DAISY BOYKIN's Avatar
Follow the positive--------------
Follow the positive cable from the battery, If it is attached to a small gray box (circuit breaker) with a red soft plastic cover. Feel around the gray box, there will be a reset button on the box. Simply push the pin to reset the breaker!!! I have a Rockwood product (5 TH wheel) my circuit breaker (two) are located behind the battery box.
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 03-10-2013, 04:40 PM   #7
Fire Instructor's Avatar
There may also be a fuse next to or adjacent to the slide motor. Mine was double-fused with one on the panel and one at the motor (I don't know why), so I removed the one at the motor.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 03-10-2013, 07:10 PM   #8
Daisy...nothing like that found.
Instrustor...nothing min line with battery and nothing own or near the motor.
But...thanks for the relies
I'm hoping someone out there has the same model rig as mine and knows the secret...'cause I damn sure don't.
Old 03-10-2013, 07:19 PM   #9
daigle01's Avatar
My camper is different than yours, but my fuse is in my front storage unit behind a false panel on the driver side of the camper. Just giving you ideas of where to look. Good luck.
daigle01 is offline   Reply With Quote
Old 03-10-2013, 07:48 PM   #10
Thought? Thanks.
So...pulled the only fuse in sight near the battery...opened the plastic case it was in, pulled the ends off the fuse (turned out to be no big deal) and took it out, inspected it and tried to run the landing gear...It wouldn't run. So, obviously that fuse was for it. Reinstalled it and the gear runs fine...BUT, I still can find the fuse for my slide!!!
Old 03-10-2013, 07:52 PM   #11
TURBS's Avatar
it may not have a fuse but rather have a circuit breaker as stated above ......
Some are resettable some are not .
My slide fuse albeit a different camper is in the fuse panel distribution panel.
Old 03-10-2013, 07:56 PM   #12
TURBS's Avatar
You didn't see one of these ? Click image for larger version
Old 03-10-2013, 08:38 PM   #13
VinceU's Avatar
Normally the fuse or breaker (can be a 1/2" square by 1.5" long cartdrige with small reset button) is located close to the power source or in a panel. It could be close to the motor but its unusual. Didn't they provide a manual source to bring it in like a long portable crank handle? sometimes a button cover on outside the slide in line with the motor mechanism, maybe 1/2 to 3/4" drive head on it.
Old 03-10-2013, 08:44 PM   #14
Originally Posted by f1100turbo View Post
You didn't see one of these ? Attachment 25384
Yeah...it looks a tad different...but, guess I can use your expertise on what I should do having seen it...
Thanks.
Old 03-10-2013, 09:35 PM   #15
VinceU's Avatar
Thanks.
I think Turbs is off line. I believe he is suggesting that is a one time fuse. can get at Auto supply stores. Best to test it first, without a meter you can tape two pieces of wire to a 12 volt bulb. Arrange test leads either side of fuse one at a time, with the 2nd lead attached or touching ground, clear area of frame will do. Bullb will light on input cable side, should light on 2nd side also, if not the fuse is blown and must be replaced.
Old 03-10-2013, 09:36 PM   #16
Derick441's Avatar
If you look at the fuse panel inside where the small spade fuses are and have someone else press the button for the slide at the same time a red light will light up beside the blown fuse.
Derick441 is offline   Reply With Quote
Old 03-11-2013, 08:56 PM   #17
Turbo...I replaced this today...still no luck. The landing gear works fine, but the slide doesn't, so I'm guessing it's somewhere down the line...what say yee?
Any idea appreciated....TC
Old 03-11-2013, 09:01 PM   #18
TURBS's Avatar
sorry I couldn't or didn't answer your question last night......
Do you have power at the slide motor ?
ONE of the best items you can have in your camper is a simple volt ohm meter.
You'll be surprised how much you'll use it !
They range from 10.00 to 250.00 and A ten dollar one will do just fine.
You need to do some testing and its best if you do it with a volt ohm meter.
Turbs
Old 03-11-2013, 09:05 PM   #19
Right you are...so, WILCO. Thanks for trying to help a lost soul...TC
Old 03-11-2013, 09:10 PM   #20
TURBS's Avatar
When you get a meter I would start at the slide motor connection and work your way from there .
Obviously it would be great to know if you had a breaker as I posted above or a fuse thats inline or even in the converter fuse panel.
Speaking of your fuse panel are your 12 volt circuits not labeled ?
Mine happen to be all labeled and the fuse for slide say "main slide" .
Turbs
