Old 03-25-2012, 07:30 PM   #1
Help With Fuse Box
Just got out my camper this summer and a few fuses blew. espically the 10 amp that runs the lights and the 25 amp which i don't know what it does. When i replaced the 25 amp fuse it arced and the trouble light was on. When i replaced the fuse it arched and the trouble light does not work now. Should i be concerned or should i let it go or what please help me !!!!
JakeGirty is offline   Reply With Quote
Old 04-03-2012, 07:43 PM   #2
Herk7769's Avatar
OK Jake,
Here is the deal. "I have an electrical problem" is not a good way to get help. We don't have a clue what kind of camper you have let alone what your issue might be. Detailed troubleshooting requires detailed information on the problem. Sometimes photos help.
I doubt someone is going to jump right in with "the solution" with so little to work with.
Over...
And yes, you should be concerned about blown fuses and arcing in the panel.
HAM CALLSIGN - KC3FFW
Old 04-03-2012, 07:46 PM   #3
TURBS's Avatar
I agree with herk more info is needed.
are the fuses labeled at all ? mine all are from the factory .
Old 04-03-2012, 08:44 PM   #4
backin15's Avatar
Its possible a mouse used your wiring harness for a snack over the winter. The fuse panel is easy to pull (unplug shore power and disconnect the battery first!) so you can check the wiring behind it. If the problem isn't there you will need to trace the wiring to the fixture the blown fuse protects. Hopefully the short will be easy to find.
backin15 is offline   Reply With Quote
Old 04-03-2012, 09:07 PM   #5
Herk7769's Avatar
With more than one fuse blown and arcing I doubt it will be obvious.
Easy to chew through a wire (stuff don't work). Much harder to remove insulation then get the wire to short to ground. (and it is wire(s) in this case.)
