04-11-2017, 08:13 PM
Hide-a-Spare mounting
My 8528RKWS has the insulation underneath, stretching from one side of the frame to the other. How will this impact installing the Hide-a-Tire rack? I'd really like to get it off my rear bumper.
04-11-2017, 08:28 PM
Left Coast
Cut it....
04-11-2017, 08:32 PM
Who Dares, Wins
I'm pretty certain they make various versions, one for your usage.
2015 Chevy HD D-Max
2022 Impression 315MB
04-11-2017, 09:16 PM
After digging a little deeper, you're right. There's an under slung model that should do the trick.
04-12-2017, 07:44 AM
I would be interested in seeing how you mounted this tire rack, as I have a Rockwood 5ver I want to do the samething with. Could you update us with pictures when your done?
Jim & Evelyn Tatum
2023 Columbus River Ranch 391MK
2022 Dodge Ram 3500 Big Horn Diesel
Nights Camped 2023 = 30
Nights Camped 2022 = 40
04-14-2017, 08:40 AM
I took a close look at my camper yesterday after reviewing the installation instructions and looking at pictures. The bottom skirt of my camper turns and extends all the way to the I-beams, overlapping the insulation there, and then secured with a strip and screws. It looks like there would be zero chance of road spray during rain getting into that area, as it is now. I will have to cut & modify the skirt to get access to the I-beams. I'm going to give this some more thought about how to address that before I install it (if?).
04-14-2017, 08:59 AM
I don't have an enclosed belly, but here's some pics and details on installing mine. Might help you some.
http://www.forestriverforums.com/for...ite-91088.html
2011 Traverse LT, 3.6L, FWD
04-18-2017, 10:08 AM
Failure is my business
https://www.amazon.com/BAL-28218-Hid...2528003&sr=8-1
I installed this one under my insulated 832IKBS. No issues.
Just make sure you get the appropriate one for the type of frame you have.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 24 Cedar Creek 40CBK
04-18-2017, 10:44 AM
you do not have to cut or modify the skirt. at least I did not. My skirts hang low also. what I did was change the direction of install. instead of having the drop down on the door side, I moved it to the ditch side and there was a lot move room over in that side. If I need to, I can move my slide out a little to have more room. As stated, I know that there are 4 different designs of the hid-a-spare for attaching to the under carriage. Get the design for your unit.
Brother Les
04-18-2017, 03:38 PM
Here's their model identifier document.
04-18-2017, 03:44 PM
Do you have pictures you can share?
Jim & Evelyn Tatum
04-18-2017, 04:15 PM
Here is a pic
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
04-18-2017, 04:51 PM
Look at post #12 rmac04401
If the drop down side was put on the stairs side of my unit.... the stabilizers would be in the way.. the steps were in the way... the gas lines were in the way... and the skirts hung low... by swinging it around to the drivers side the tire and drop down is clear of everything and the tire is under the water tank (if the tank falls out ) ..... and is fairly clear of the skirts and if I need I can move the slide out. my first post I said the ditch side drops down, I mean that it is the side opposite of the door and the truck drivers side that drops down.
Brother Les
04-18-2017, 07:13 PM
With exception of the slide, my skirts wrap completely under the bottom and attach at the frame. Of course, in the slide area, the driven shaft extends the full length of the slide. My gas line runs just underneath the frame on the door side of the camper. I'm really not seeing an easy way to make it work behind the axles now, which is what I prefer. I'll keep thinking about it though.
04-18-2017, 09:25 PM
mine is in front of the axles
Brother Les
04-18-2017, 10:08 PM
Give BAL a call and talk to them about it.
04-27-2017, 08:16 PM
I talked to John Hawkins with Norco Industries today. Nice guy. He was familiar with units like mine that wraps the skirt underneath and attaches to the frame. Unfortunately, it seems like I'll have to cut the skirt to clear the rack on the passenger side, then modify the skirt to make it sturdy again. The driver side pivot could be mounted behind the slide out shaft, so that skirt won't interfere.
One remote possibility would be to mount behind the entry steps, but obviously, access would be restricted.
05-02-2017, 07:48 AM
Does your FW have opposing slides? Thats what I have and I was considering mounting one between the slideout rams.
Jim & Evelyn Tatum
05-02-2017, 08:11 AM
No, only on one side.
He mentioned that when mounting in the area of the slide outs, you can loosen one end of the shaft between the rams, and slip the mount behind it.
If your I-beams aren't covered by the lower skirts wrapping around them, the installation looks pretty straight forward.
05-07-2017, 07:36 PM
I was thinking about the same system and almost bought one. Then after packing my basement I found I have plenty of room for spare. That's were it's at now, dry and easy to access.
2017 Flagstaff 524RLWS
2015 F150 , 5.0 , 3:55 axle
