Old 07-19-2018, 02:15 PM   #1
Hitch light 21DS
Can anyone tell me why my tongue light would not work? The hitch works but light won’t come on?? If I need to replace it, where can I get one??
ShortyMc40 is offline   Reply With Quote
Old 07-20-2018, 08:31 AM   #2
SeaDog's Avatar
How do you know the switch works? Did you test it with a meter, very often the reason for lights not working are the ground connections.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 07-20-2018, 10:34 AM   #3
How do I take the switch off to check? I have a meter.
Old 07-20-2018, 10:49 AM   #4
SeaDog's Avatar
Assuming your switch in in the power head of the tongue jack you can remove the screws holding the plastic on the power head and get at the back of the switch to test it without removing it from the plastic (my first choice) or you can pop the switch out of the plastic and then test it. also you should follow the wiring to the lights to ensure it is intact.
Retired Navy
hitch, light
