Old 05-26-2018, 02:39 PM   #21
Best source of rubber for under a battery is a piece of mud flap. Also good idea to put the same over the top of the battery so its protected from shorting due to dropped tools ar the like.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 05-26-2018, 03:25 PM   #22
Originally Posted by spydunks View Post
When I got our new trailer home I found the same thing. In my case the self-tapping bolts were put through the raised part of the box, and the bolt heads were rubbing the bottom of the battery. I relocate the bolts to the depressed area, so they didnít rub.
Seems like an easy issue that should have been caught at the factory or dealer.
Hmmm...the self-tapping bolts (my hubby just told me that's what they are called in my battery case...) on mine were in the RIGHT place (the depressed areas), but still, they were too high. At any rate, you would think that the dealerships would get this right! Looks like a no-brainer to me!
Bev4banff53 is offline   Reply With Quote
Old 05-26-2018, 03:39 PM   #23
Again, glad you got a new battery.
Did you change out the "Too high" bolts or are you just putting in the rubber to cover up the mistake?
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 05-26-2018, 07:16 PM   #24
We just put a rubber mat inside, but it's pretty thick and would take A LOT to go through it. I think it's going to work very well.
