Old 02-14-2015, 05:38 PM   #1
Hot water by pass
2015 FLAGGSTAFF 8524, just picked it up yesterday. I read all the info on winterizing and looked in the cargo area where the pump filter are located. All I could see is one valve in there I am used to 3 valves on my other rigs. Don't see anyway to get to the back of the water heater. Is that 1 valve the bypass?. Please advise.
FOREST RIVER FW 8524RLWS
2010 FORD F 150 5.4
#1-18' Nomad #2- 20' Mallard #3- 27' Sunline #4- Four Winds C #5- Innsbruck 40' PARK # 6- 28' Amerilite #7- Forest River 26.5 FW ( 1st FW)
SULTINI is offline   Reply With Quote
Old 02-14-2015, 05:50 PM   #2
Ford Idaho's Avatar
Look from inside where you feel the back of the water heater is, there should be a panel with 2-4 screws holding it on.
Remove panel get down with a flashlight.
If you would not mind please post an IMG of the valve you posted about.
Old 02-14-2015, 06:34 PM   #3
caper's Avatar
It could be one valve with a check valve on the hot water outlet. If it is one valve when the lever is pointing towards the WH cold water is being supplied to the WH. When the lever is pointing up it is bypassing the WH.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 02-14-2015, 07:24 PM   #4
Old Bleu's Avatar
I think your single valve at the pump is to control whether the pump pulls from the freshwater tank or the antifreeze port. Your bypass valves are likely at the back of the water heater.
2019 Cedar Creek Silverback 33IK
2016 RAM 2500 Laramie Cummins Turbo Diesel
Old Bleu is offline   Reply With Quote
Old 02-14-2015, 07:34 PM   #5
Ret E-9 Anchor-clanker
donanddona's Avatar
My flagstaff 8528 BHSS has the water heater under the sink. I have to remove the bottom drawer and to the right is the water heater, and three manifold with bypass. Good luck!
donanddona is offline   Reply With Quote
Old 02-16-2015, 03:55 PM   #6
I want to take this time to thank you for all your reply's. I got it . Remove kitchen drawers, reach in by pass valves there. Under storage compartment valve to pump antifreeze in to system. I was just a little Hyped never had a FW before. Should have known better all the rigs I have winterized in the past. Guess the new toy got to me. Your reply's all got me thinking.
Happy Camping
1st trip to Florida this Sunday.
PS: need to winterize on the way home.
Sultini
2010 FORD F 150 5.4
hot water, water
