Old 07-23-2017, 11:34 PM   #1
Rangie's Avatar
Hot Water trickles
We are new to the camping lifestyle. Can someone explain to me what these buttons and switches do?
Also our hot water is trickling slow from the faucets. Is the valve at the water heater stuck or bad?
Thanks for the helpClick image for larger version
ID:	145866Click image for larger version
2011 Flagstaff Super Lite
Rangie is offline   Reply With Quote
Old 07-24-2017, 05:42 AM   #2
The switch on the left is the 110 volt power switch. Sometimes there is a second switch on the control panel. The buttons are reset buttons when there is a problem with the heater.
DanMistyMiller is offline   Reply With Quote
Old 07-24-2017, 10:28 AM   #3
Rangie's Avatar
Ok, thanks Dan.
Old 07-24-2017, 10:59 AM   #4
wmtire's Avatar
Thanks for the helpAttachment 145866Attachment 145867
This should help explain how your Suburban water heater works:
Suburban's electric switch and much more
As per the hot water trickling, please watch videos #3 and #4 here to make sure you have the winterization/bypass valves set correct as well as flushing the tank to make sure you don't have crud clogging something up.
Suburban Water Heater Video Guides
Hope this helps
2011 Flagstaff 831 RLBSS
Geaux Tigers!!!!
Old 07-25-2017, 06:58 PM   #5
Rangie's Avatar
Thanks for the input friends. We figured out that the shutoff on the hot water line was stuck closed. Replaced now back in business.
hot water, water
