You should plan on staying at a camp ground closing the dealer for the weekend. Should any issues arise over the weekend, your close enough to take care of it. There should be a link on one of these topics for the walk through of your camper. Print it out and follow it. Also read a bunch of messages from other owners (keep n open mind) as to what they found and did about it. Good luck.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Congratulations on the new RV. My suggestion would be since you live so far away, see if they will put you up in a camp ground close by for a night or two to make sure everything works and that you are a happy camper
Pennie and Chuck, Mandi and Polly (the little dogs)
Hosted BamaGanza 2017 & 2018
2014 Georgetown XL378, 2014 GMC Acadia Denali Toad
Have a look by the entry step and outside kitchen for two grommet where the manual handle will fit. You should have a manual handle usually in the couch drawer. For your awnings you should have instruction sheets for them.
If same as mine the cranks should be in the front storage compartment brackets on wall. I have 2011 no issues to date (knock on wood). Did a few mods pantry draw are now slides, under queen bed put plywood down for more storage, and this way draws below are not interfered with.
Essex County
Southern most area in Canada
2017 F250 Lariat 6.7superdutyTurbo Diesel
2011 Flagstaff classic 31.5'BHDS
..and if you find the grommets, but don't see anything to slide the wrench on, look to the left and right inside the hole the grommet(s) are in. You'll need a flashlight.
On the V-Lite 26WFKSS we looked at at the dealers, the aft hole was off by about 2 inches. That would be a surprise in an emergency.
Screen shots?
2014 Flagstaff 831BHDS
2010 Ram 2500 Cummins 4.10s - Superchip'd
Built-in Controller
Hellwig Sway Bar 7272
Equalizer Hitch system
You guys will enjoy it, we have had our 2013 model for the past year and have had it out several times and really enjoyed it. Good luck and enjoy it as much as you can.
Okay I did a complete demo video when I picked up the camper. (I will post this soon)
What I didnt get out of it:
1. Where is the water filter?
2. The city water connection is the 'top port' in the rear [its not labeled]
Built-in Controller
1. my 2011 water filter is in rear bunk house. right to the back bottom left there is a panel screws need to be removed and it is behind that. this may help on the exterior of this location is my outside shower
2. Yes it is for my 2011. that should be same as the water filter most likely is on the interior of the water connection,
I will try and post some pictures to help if no else can, I will have my trailer out of storage this week for sure. Hope this helps
Essex County
