Old 04-17-2014, 09:16 AM   #11
this is good info, but the two slides where are those manual cranks?
2014 Flagstaff 831BHDS
2010 Ram 2500 Cummins 4.10s - Superchip'd
Built-in Controller
Hellwig Sway Bar 7272
Equalizer Hitch system
Long Islander is offline   Reply With Quote
Old 04-17-2014, 09:51 AM   #12
Gripper's Avatar
If same as mine the cranks should be in the front storage compartment brackets on wall. I have 2011 no issues to date (knock on wood). Did a few mods pantry draw are now slides, under queen bed put plywood down for more storage, and this way draws below are not interfered with.
Essex County
Southern most area in Canada
2015 F150 XLT Sport 5 ltr V8
2011 Flagstaff classic 31.5'BHDS
Gripper is offline   Reply With Quote
Old 04-17-2014, 10:14 AM   #13
Originally Posted by fonzie View Post
Have a look by the entry step and outside kitchen for two grommet where the manual handle will fit. You should have a manual handle usually in the couch drawer. For your awnings you should have instruction sheets for them.
..and if you find the grommets, but don't see anything to slide the wrench on, look to the left and right inside the hole the grommet(s) are in. You'll need a flashlight.
On the V-Lite 26WFKSS we looked at at the dealers, the aft hole was off by about 2 inches. That would be a surprise in an emergency.
katkt is offline   Reply With Quote
Old 04-17-2014, 10:19 AM   #14
Screen shots?
Built-in Controller
Old 04-17-2014, 12:52 PM   #15
Gripper's Avatar
Sorry Trailer still in Storage :0(. I will attempt in a few weeks
Essex County
Old 04-18-2014, 08:12 AM   #16
Mgel2584's Avatar
You guys will enjoy it, we have had our 2013 model for the past year and have had it out several times and really enjoyed it. Good luck and enjoy it as much as you can.
Mgel2584 is offline   Reply With Quote
Old 04-28-2014, 08:47 AM   #17
Okay I did a complete demo video when I picked up the camper. (I will post this soon)
What I didnt get out of it:
1. Where is the water filter?
2. The city water connection is the 'top port' in the rear [its not labeled]
Built-in Controller
Old 04-28-2014, 01:25 PM   #18
Gripper's Avatar
1. my 2011 water filter is in rear bunk house. right to the back bottom left there is a panel screws need to be removed and it is behind that. this may help on the exterior of this location is my outside shower
2. Yes it is for my 2011. that should be same as the water filter most likely is on the interior of the water connection,
I will try and post some pictures to help if no else can, I will have my trailer out of storage this week for sure. Hope this helps
Essex County
Old 05-06-2014, 08:44 AM   #19
Okay fellow members, we will be camping this weekend, taking the new camper on it's maiden voyage this weekend with the family.
Built-in Controller
Old 05-06-2014, 11:45 AM   #20
fonzie's Avatar
Did you ever find the manual cranks for the slides? Happy camping.
Fonzie
