Old 07-29-2014, 08:57 AM   #11
Originally Posted by army_jedi View Post
Pretty new to this, you would use the external filter between the source and your regulator? Then regulator to RV? Thanks!
The Camco filter I use attaches to my city water inlet on the side of my trailer with a spring reinforced piece of hose so the weight of the filter doesn't kink the hose. The pressure regulator connects to the other end where you connect the hose at the source.
Amazon.com: Camco 40043 TastePURE Water Filter with Flexible Hose Protector: Automotive
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 07-29-2014, 06:57 PM   #12
Regulator goes upstream of anything you want to protect. I put mine at the spigot thereby protecting all my equipment.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 07-29-2014, 07:27 PM   #13
I use Camco filter and it works great, but my TT also has a filter, so the water in my camper is awesome.
Uncle Buck is offline   Reply With Quote
Old 07-29-2014, 07:34 PM   #14
kc8lvy's Avatar
We will be Full timing so i am using Filter,Water Softner,under sink drinking water filter.
https://www.flowpur.com/html/rv-pro10000.html
http://www.amazon.com/Whirlpool-WHED...omplete+System
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 07-29-2014, 08:20 PM   #15
Me too, but I also have a Brita pitcher for water we drink. The water is excellent wherever we camp.
Regards,
Wayne
Old 07-30-2014, 07:17 AM   #16
Originally Posted by youroo View Post
We use a whole house filter mounted (Outside) it has a Clear housing so you can see what is running thru it! With this type of filter (You) can (Select) what (Element) you want to place (Inside)! The (Element) types can Vary from filtering (Small dogs to Microorganisms that they are still trying to give a Name)! The (Price$$) will vary by (What You want to filter OUT). The price of a (Element comparable to the Blue Filter) is cheaper than F/R stock type or Ole Blue! Youroo!!
Is that a off the shelf unit and is it for use externally? I like the idea of keeping it outside and since it is permanent it would be one less thing I have to mess with when setting up.
2014 Crusader 325res Touring Edition
2003 Silverado Duramax 6.6 Dually Longbed 2wd Crew Cab
RickV is offline   Reply With Quote
Old 07-30-2014, 07:28 AM   #17
Lowes or HD shelf. It is removable.I just added a tube that slides into a tube that I mounted under unit. Youroo!!
ID:	59253   Click image for larger version
water, water filter
