07-27-2014, 11:26 AM
In-Line Water Filter
Am thinking about installing an Exterior In-Line Water Filter on my TT. Anybody else use one. Your thoughts and suggestions.
07-27-2014, 11:33 AM
07-27-2014, 11:56 AM
I've been using the Camco ones since I bought my trailer.
07-27-2014, 12:13 PM
Make sure whatever you buy you get a pressure regulator. Some parks have a lot of pressure and others not enough. They're not very expensive and a good insurance policy against a blow out. My 5th came with a filter but I also use a camco filter before my water regulator
Columbus 365RL
Powered by a Ford F-350 Super Duty Diesel
07-27-2014, 12:40 PM
We've used both the RV canister units and the "built-in ones" that came in our 3 class A mh's. We, after 50 years of RV'in in 10 different units, prefer the RV canisters. All the water connections are outside the RV in case of a connection leak and changing filters/filter elements is easy with no chance of water spilling in the cabinet or bay in which the filter resides.
07-27-2014, 02:10 PM
Walmart sells some inexpensive ones - just get one of those and use it. I have been using the blue ones from Camco for years and have had zero issues.
07-28-2014, 07:10 AM
Camco Filters
X2 - I test water pressure with a gauge before hooking up, and decide whether to use the pressure reg or not. At a recent stay it was only 22 lbs. I attach the Camco filter right at the mast. If anything blows, it's 30 feet away from my trailer. Water flow to the shower is still fine.
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
07-28-2014, 07:45 AM
We use a whole house filter mounted (Outside) it has a Clear housing so you can see what is running thru it! With this type of filter (You) can (Select) what (Element) you want to place (Inside)! The (Element) types can Vary from filtering (Small dogs to Microorganisms that they are still trying to give a Name)! The (Price$$) will vary by (What You want to filter OUT). The price of a (Element comparable to the Blue Filter) is cheaper than F/R stock type or Ole Blue! Youroo!!
07-28-2014, 07:36 PM
Anytime you can move water filters/connections outside of your TT....you have won! Impossible to predict when a leak will began. Put your filter outside.
SPARKEY BOB
IBEW LU 613 Atlanta
Micro Lite 21 FBRS
Toyota Tundra
07-28-2014, 08:25 PM
Pretty new to this, you would use the external filter between the source and your regulator? Then regulator to RV? Thanks!
Cheers,
Army Jedi
2015 V-Lite 30WRLIKS (soon), 2005 F150 FX4
1974 Wife, hottie model with all the options
2013 German Wirehaired Pointer (Holmes)
2013 Wirehaired Pointing Griffon (Watson)
07-29-2014, 08:57 AM
The Camco filter I use attaches to my city water inlet on the side of my trailer with a spring reinforced piece of hose so the weight of the filter doesn't kink the hose. The pressure regulator connects to the other end where you connect the hose at the source.
Amazon.com: Camco 40043 TastePURE Water Filter with Flexible Hose Protector: Automotive
07-29-2014, 06:57 PM
Regulator goes upstream of anything you want to protect. I put mine at the spigot thereby protecting all my equipment.
07-29-2014, 07:27 PM
I use Camco filter and it works great, but my TT also has a filter, so the water in my camper is awesome.
07-29-2014, 07:34 PM
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
07-29-2014, 08:20 PM
Me too, but I also have a Brita pitcher for water we drink. The water is excellent wherever we camp.
07-30-2014, 07:17 AM
Is that a off the shelf unit and is it for use externally? I like the idea of keeping it outside and since it is permanent it would be one less thing I have to mess with when setting up.
2021 Alpine 3790FK
2021 F-350 SD XLT PS 6.7 Dually Longbed 4wd Crew Cab
07-30-2014, 07:28 AM
Lowes or HD shelf. It is removable.I just added a tube that slides into a tube that I mounted under unit. Youroo!!
