Old 01-31-2016, 06:21 PM   #1
SeaDog's Avatar
Interior light/lights
New on site not to RVing downsized to a 2016 26'FKWS Flagstaff TT From a Class A Winnebago. I'm very impressed with this TT, with that said I sure don't like that the only entry lite (switched from the panel) is over the sink area and all other lights except the bathroom lights must be turned on and off individually. Has anyone wired other lights to come on with the entry switch or installed a light over the switch panel?
Old 02-01-2016, 10:54 AM   #2
To do what you want to do you will need to snake some wires. That can be real frustrating and may require a sailor rich vocabulary. If all you want is some light until you can get to other switches, just add a few LED motion detector lights with on/off switches built in.
limblips is offline   Reply With Quote
Old 03-16-2016, 10:17 PM   #3
We bought a couple of wireless switches for some of our lights light bedroom lights and living room lights.
led346 is offline   Reply With Quote
Old 03-16-2016, 10:35 PM   #4
Installed a light over the "Black light panel with the Black switchs" hard to find Panel in the Dark! Youroo!!
Old 03-16-2016, 10:42 PM   #5
Left Coast
X2
Old 03-17-2016, 07:22 AM   #6
SeaDog's Avatar
I actually solved the problem of the entry light by installing a nice LED light over the switch panel and adding two 3 inch slim round LED under the cabinets and removing the light FR had installed from the circuit and put it on the same circuit with the other living room lights.
Now when I hit the switch the two little pancake lights give off just enough warm white light and the light over the switch panel makes it east to see the switches problem solved.
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-17-2016, 08:33 AM   #7
jeff64's Avatar
Do you have an outlet near the entry door that you can just plug in a night light, maybe even one with a photocell to come on when it gets dark? Sure would save you a lot of hassle
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 03-17-2016, 08:52 AM   #8
SeaDog's Avatar
This project has turned out great the only tough part was finding the wires behind the Microwave and then fishing new wires thru the false bottoms of the cabinets. I will take some pics next week or so and post.
Retired Navy
Old 03-17-2016, 08:52 AM   #9
Left Coast
This light also doubles as a portable work light......reinforced inside of wall with backer boardClick image for larger version
ID:	102140 Battery and LED, swivel head.....light weight plastic
Sent from my XT1080 using Tapatalk
Old 03-17-2016, 09:02 AM   #10
Left Coast
While your pull'n wire, add cabinet inside lights...
light
