Old 06-17-2014, 08:36 PM   #1
Timex's Avatar
Jack Antenna Light
Since I have not received a response from another thread, I'll start a new discussion. I've search all the other threads on FRF about the Jack antenna and haven't seen my exact situation.
Purchased the replacement head from CW and installed today. I followed the mounting instructions exactly. I checked the channels before doing anything and received 16 channels with the original batwing. Mounted the Jack and still 16 channels using the onboard amplifier that came with the TT. The light on the bottom is very dim. Is it supposed to be noticeable? I plugged the TT into shore power to top the charge on the battery that was a little low. Would the battery being a little down hurt the amplifying power of the booster and effect the brightness of the light on the bottom of the Jack?
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 06-17-2014, 08:45 PM   #2
Herk7769's Avatar
"onboard amplifier that came with the TT." You are talking about the power supply and not the amplifier. The amplifiers are in the antenna head (both the batwing and the Jack).
If the Jack is not getting power it could be your battery is too low to push all the way up the coax to the Jack or it could be you have a pinched wire shorting out the Jack itself.
HAM CALLSIGN - KC3FFW
Old 06-17-2014, 09:08 PM   #3
Timex's Avatar
I stand corrected on the amplifier. The power supply for the antenna is inside a cabinet door and turns on(green light) when the button is pushed in. When I "unpush" the button (green light off) the channels fade out. So I feel like the power supply is working. You mentioned a pinched wire. Could that be in the antenna itself? I'll give the battery a couple days to charge fully and check things again.
Old 06-17-2014, 09:10 PM   #4
Herk7769's Avatar
The power supply is also a source switch. With the light ON you select the roof antenna and with the light OFF you select the park cable input on the side of the camper.
Name:	Winegard wall plate rear.JPG
Old 06-17-2014, 09:18 PM   #5
VinceU's Avatar
While you are waiting be a good chance to clean the connector wires cap and threads and well as center conductor most loss is often in the RG59 connectors.
VinceU is online now   Reply With Quote
Old 06-17-2014, 09:30 PM   #6
Timex's Avatar
I wiped the coax connector out before screwing into the female outlet on the antenna. The instructions say to not over tighten the connector. I finger tightened and then used pliers to snug it up to keep it from vibrating loose. Included in the box was a dab of dielectric grease. I didn't put that on, didn't think it would matter.
This TT has spent about 6 weeks outdoors since I've owned it. And I don't think it sat on the dealer's lot for very long because they hadn't done a whole lot of prep work before we bought it. FWIW. I guess I'm hoping for a weak battery. My next purchase will be a battery tender so things like this won't happen.
Old 06-17-2014, 09:57 PM   #7
VinceU's Avatar
That's good the wiring is in good shape and the grease will help it stay that way. Question though I didn't see where you rotated the batwing from inside to improve the reception LED's on the case? I've seen them bring in HD signals but not sure at what distance that will happen.
Old 06-17-2014, 10:45 PM   #8
I also have the same expereince - after I mounted the Jack Replacement Head I noticed that the light on the underside of the head appeared to not be "obviously" on, and I could not tell whether it was the light from sun making it look as if it was on or not. I installed it before breakfast one morning as the sun was low in the sky. The RV was on shore power and the stitch at the wall plate was on (no trouble seeing its light). Anyway I figured since the TV was picking up channels then the amplifier in the Jack Head must be working. I tested that by pushing the wall plate switch and watching the reception disappear.
I never did check the Jack Head light in the night time. Maybe if I remember next time I go camping.
As far as performance goes - I have only had limited time with it but its performance has not blown me away compared with the Winegard Sensar IV with Wingman that I took off. More assessment to come I suppose.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 06-17-2014, 10:45 PM   #9
Fore Aces's Avatar
Timex, I too just replaced the batwing with the Jack replacement head. I also did NOT see improvement in channels/reception that reviewers bragged about. Light on Jack antenna was hard to see on sunny day but believe it was sort of flickering instead of a steady light. I rotated both antennas to determine best signal direction.
I have a different set up for power booster. I have a Winegard Video Distribution Center that has the booster incorporated into it. I was wondering if the Jack provided booster was a better match than using the existing booster?? I DO know not to use both together because that could damage system.
Thanks Herk for the suggestion to check house batteries. I will check them and see if that helps. Any other suggestions would be appreciated. I would like to give the Jack a great review too but cannot do at this time.
2006 Charleston 400
Pushing Charles - 2011 GMC Terrain
Helmsman - Dave
Navigator - Gail
Louie & Cleo - Jack Russell's (Rulers of the Roost)
Fore Aces is offline   Reply With Quote
Old 06-18-2014, 05:07 AM   #10
RPAspey's Avatar
The blue light on the bottom of the Jack antenna is only for the signal strength. There's a little adjustment screw there as well. That screw is for the strength meter gain. It does nothing for the reception. In the case of too strong of a signal or too weak of a signal, you can turn that (+\-) to adjust the gain of the SIGNAL METER only. So, lets say your blue lights are all on. Turn that screw down a bit and you should be able to zero in on the exact location of the signal. Oh, if the blue light(s) bothers you, turn the switch off thats located on the side of the Jack head.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 06-18-2014, 05:09 AM   #11
RPAspey's Avatar
If the light barely turns on, turn up the gain and then aim the antenna. Again, the switch on the side is foer the blue light meter only. The adjustment is for the blue light only.
Old 06-18-2014, 07:19 AM   #12
Herk7769's Avatar
Use a program like AntennaWeb - Home to find out the direction to point the antenna AND the available tower to aim at.
Trying to get blood from a stone is counterproductive.
Name:	Antennaweb Roadmap Wide angle.JPG
ID:	55668   Click image for larger version
Name:	Antennaweb Satellite Wide angle.JPG
ID:	55669   Click image for larger version
Name:	Antennaweb Satellite at Camper.JPG
Old 06-18-2014, 08:49 AM   #13
RPAspey's Avatar
We use that app too. But barely watch TV.
I wanted to respond to the poster who had problems seeing the blue light during the day.
Old 06-18-2014, 03:42 PM   #14
Timex's Avatar
I didn't purchase the signal meter that goes inside the TT. On my tv(as probably other's as well) there is a signal meter for each channel. I understand that the Jack is more directional sensitive than the batwing. And no, I didn't turn the antenna in different directions. I was trying to compare apples to apples. As a matter of fact, the TT is inside my building! But that shouldn't matter in this case because some people mount antennas in their attic. I was concerned that the red light on the bottom of the antenna(being dim) would have something to do with the power of reception.
I think I have another problem brewing though. My converter is not charging my battery. It's been plugged up to shore power for 24 hours and the battery is still the same as yesterday. I've got a charger hooked to it now to get the battery up to snuff. I'll have to study up on other threads to try to see what's going on with the converter.
Old 06-18-2014, 03:50 PM   #15
VinceU's Avatar
Check the battery fuse first. Normally a resettable fuse with a reset button on the side, located on the positive battery cable 12-18" from the battery on the trailer frame.
Old 06-18-2014, 03:55 PM   #16
Timex's Avatar
Before I check this, let me ask; if the battery is not charging, would it be able to power the lights, etc? I have lights and slides work but the lights are not their brightest and the monitor panel says the battery is 1/3.
Old 06-18-2014, 04:07 PM   #17
RPAspey's Avatar
Nope, I don't think the converter is charging. Do you have a multimeter? If so, measure the voltage at the battery and again at the converter output. Then report back & we'll help out!
Old 06-18-2014, 04:15 PM   #18
Timex's Avatar
Before I put the charger on the battery it read 11.63.
Where can I find the converter output?
Old 06-18-2014, 04:20 PM   #19
VinceU's Avatar
The answer is yes, if the converter is working you would have lights w/out a battery. Use a meter and you can tell which is providing the power. Even still one light would be like candle light.
Old 06-18-2014, 04:28 PM   #20
VinceU's Avatar
Converter normally located as lower half of fuse/circuit breaker panel. Remove hinged door you can access DC buss connections.
antenna, light
