Old 06-17-2016, 09:47 AM   #11
SeaDog's Avatar
You have made great use of the space, FR cushions are not very good. Nice camp site
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 09-04-2016, 12:17 PM   #12
decor
Great lay out looks very comfortable and easy to set up.
OBTW does your travler have battery cut off switch and where is it (if you have one)
2015 Forest River 21 DS
1999 F350 super 7.2 diesel
Showing basenjis
almasibasenji is offline   Reply With Quote
Old 09-04-2016, 12:22 PM   #13
Cut_un's Avatar
My 21 DSDoes.. The switch is located just under the right propane tank ( standing in front of the tongue) in front of the battery.
2016 Flagstaff MicroLite 21DS. Ford F-150 extended cab , 5.4 Triton V8
Cut_un is offline   Reply With Quote
Old 09-04-2016, 04:54 PM   #14
dmchapman's Avatar
We noticed our sofa was sagging, particularly the front center. It was resting on the drawer front and would drop about 1 1/2 inch when the drawer slid out. I found the front of the frame is bent downward! I am currently looking for a 63" piece of 1" heavy wall box tubing to span the opening and support the sofa. I also need to figure out how to remove the downward bend in the frame. I haven't determined yet if the frame at the back of the seat cushion is also bent. If I am not successful in shoring this thing up I might pull it out and replace it with a 72" long futon from WalMart.
dmchapman is offline   Reply With Quote
Old 09-11-2016, 10:40 PM   #15
dmchapman's Avatar
I was able to straighten the front frame by supporting the center with a jack and bouncing my full weight on each end in turn. I cut. 63" piece of 1" square tubing and it fit into existing brackets as if this was what was intended. I drilled through holes in the ends and fastened with small sheet metal screws. Finished with thick stick on felt pads at contact points. Feels solid. Hope it holds up under our combined weight 🙄Click image for larger version
Name:	ImageUploadedByForest River Forums1473651559.785050.jpg
ID:	119980Click image for larger version
Name:	ImageUploadedByForest River Forums1473651586.035551.jpg
ID:	119981Click image for larger version
Name:	ImageUploadedByForest River Forums1473651612.236833.jpg
ID:	119982Click image for larger version
Name:	ImageUploadedByForest River Forums1473651635.073289.jpg
2015 Microlite 21 DS
2012 Silverado extended cab Z71
