Landing gear clicking noise.....
When raising my front landing gear it's making a loud clicking noise but working ok. I'm hoping I don't have a broken tooth on a gear. I did grease both of them and I also noticed as the button is depressed going up or down the motor that is attached to the landing gear looks as though it's loose. Is that normal? Does it just float. There is a tie wrap from the factory that go's up and around the square shaft that drives both sides. If you blow up the pic you will see 2 grease fittings on the front. Thanks for some info will be appreciated!
2017 Flagstaff 524RLWS
2015 F150 , 5.0 , 3:55 axle
