Old 06-28-2013, 12:22 PM   #1
Landing gear out of adjustment
Hy all..
My front landing gears on my 2009 8524 rls fifth wheel are out of adjustment.
One side is lower than the other. How can i readjust them to the same hight??
Mike
micalo is offline   Reply With Quote
Old 07-08-2013, 03:44 PM   #2
tomjsas's Avatar
I've had to readjust mine due to a sheared bolt on one side of the landing gear mechanism. I assume yours is an electric motor set up like mine. You need to be hooked to the tow vehicle to provide support while doing it. The way I did it was to remove the bolt from one side of the shaft via the front compartment. For me it was easiest to remove the bolt on the passenger/camp side of the unit since the motor was not in the way. I then ran the other leg in or out as needed to even up, measuring to make sure it was as close as possible. I then reinserted the bolt and tighten it back up. They are within about 1/8th of an inch now. Hope that helps.
Tom
2004 Fleetwood Providence 38U
currently not towing a toad
tomjsas is offline   Reply With Quote
Old 07-08-2013, 04:17 PM   #3
Thank you so much
Ill look into it this week, and hopefully get it back to where it should be.
Old 09-17-2013, 06:00 PM   #4
tomjsos.
Thank you again for your explanation... Took a while but finnaly got to it this weekend... Very easy to do took about 5 - 10 min. Again clear instruction ma
de it easy.
Mike
Old 09-17-2013, 06:11 PM   #5
tomjsas's Avatar
Glad it helped.
Tom
Old 09-17-2013, 06:27 PM   #6
5er_tom's Avatar
During a pull test, I managed to drag one of the landing gears, actually pulling out the locking pin of the foot. The result is I cannot use the landing gear foot.
My question is, can I cut off about 2" of the landing gear shaft so the foot can again be installed into the holes?
Can I replace the sliding square part that manually lowers?
By the way, I have a 5th Wheel Leg Leveler which works great.
See it here. It is available in many RV stores.
Fifth Wheel Leg Leveler - Barker 25900 - Chocks & Levelers - Camping World
Tom & Renťe
Durham, NC
2015 Wildcat 295RSX
2018 Ford F-350, 4x4, Diesel, CC, Long Bed
5er_tom is online now   Reply With Quote
