Old 11-17-2018, 12:52 AM   #1
Leak, humidity or weak glue
I have a couple of windows that have bubbling underneath them. No moisture felt, no puddles, but, Iím concerned. Last photo, none of the windows have caulking around them, which I could do. Click image for larger version
ID:	191611Click image for larger version
ID:	191612Click image for larger version
spydunks is offline   Reply With Quote
Old 11-19-2018, 08:35 AM   #2
There was a thread here a couple years ago (by Mr. Havercamp I believe) with something very similar. He had frameless windows too and wound up having to remove them to seal.
Do you have warranty?
Days Camped: '16=46 '17=30 '18=51 '19=10
Old 11-19-2018, 10:03 AM   #3
I would guess a definite leak. The cure is to remove the entire window, frame and all, dry out the underlying structure, (and hope it's not degraded), and reinstall with proper sealant/caulking.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 11-19-2018, 10:29 AM   #4
Itís past the 1-year factory warranty, so looks like itís up to me to fix. I donít think there should be any structural issues due to the age, but I will see when we pull it apart.
Iíll hunt for that post showing the repair.
Old 11-19-2018, 04:31 PM   #5
SailorSam20500's Avatar
I had a similar issue this past spring. Initially spotted some water on the counter but no indication where it came from. During a good rain while we were in the trailer, I spotted the leak and was able to get pictures of the water coming in. Had my dealer repair. They reported that the seal around the window wasn't seated properly during install and had a "wrinkle" in it. Said they pulled the window out, adjusted the seal, and reinstalled the window, no damage to structure. Been dry ever since.
My leak was on the left side when looking at the window from inside.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 11-19-2018, 04:43 PM   #6
Here's a pic from my leak.
Al
S.E. Mich.
Old 11-19-2018, 10:55 PM   #7
I saw some water dripping on the inside wall below my dinette window once. That was the only window with a water drip. I checked the fitment of the window and it appeared good.
I did notice that the other windows had weep slots on the outside of the sliding channel for the window which I assume drained water out of the channel when wet but this window did not. Upon further checking, I noticed the weep slots had plugs in them. Removed the plugs and no more water drips in the interior.
I guess it was bad dealer prep? Not surprised.
tosh99 is offline   Reply With Quote
Old 11-20-2018, 12:13 PM   #8
DouglasReid's Avatar
Caused either by water intrusion from a leak or condensation on the inside.
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is online now   Reply With Quote
Old 11-20-2018, 06:15 PM   #9
Thank you! Iíll be pulling the window and replacing the seal. There is not a hint of caulking on the outside of any of the windows, so Iíll add that too.
leak
