Old 05-15-2011, 07:07 PM   #1
Location: No longer own a Forest River product, but enjoy the info on this site
Leaking H2O tank - Fixed
We found out the lower fitting on the back of our water heater leaked the morning of our first outing. We awoke to some wet carpet and wet tootsies.....
Luckily we were able to isolate the problem by shutting the off the valves for the water heater.... but this left us with no hot water.
Today I removed the lower fitting on the water heater and resealed it with teflon tape..... it's all good now and the h2o heater works perfectly.
Apparently, the leak emanated from the clumpy (or ill-applied) plumbers putty...
Darren
teamgl is offline   Reply With Quote
Old 05-15-2011, 07:12 PM   #2
(Kim)
Labzy's Avatar
What kind of tools do you guys bring with you when camping?
Like the bare necessities..........
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 05-15-2011, 07:26 PM   #3
sherdep's Avatar
If Darren is anything like me - (very Resourceful) - which I think he is - he will have basic hand tools
I keep a bunch of tools in my truck box including a floor jack - for the most part I am always over prepared then under prepared - Must be the Marine in me
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-15-2011, 08:10 PM   #4
I have a little cardboard box that contains my 'fix it kit' .... a screw driver, fishing pliers, electrical tape, a bandaid, and some wrenches.
This "fix" required no less than 3 trips to the local hardware store.... which is usually necessary under such circumstances. Any plumbing project requires a minimum of 3 trips to the local hardware store, don't you know!
Fixed and done....
Up next... a little 'lift' for the camper and some new shoes.... ::
See you around the campfire.
Darren
Old 05-16-2011, 03:45 PM   #5
(Kim)
Labzy's Avatar
I kinda meant, what are the usual heads and sizings that FR uses on the trailers....Philips....etc.....?
Unlike Sherdep.....I am not interested in bringing the kitchen sink = p
Im talking bare minimum here............
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 05-16-2011, 04:05 PM   #6
buckisland1950's Avatar
Better invest in some square bits (not sure of the size). That is the usual or standard for most RV/mobile homes screws. I keep a screwdriver with interchangable bits on hand as well as the usual vise grips and set of sockets and a handy voltmeter.
2011 F250 Lariat Crew Cab 6.7L Diesel
2011 Flagstaff Classic Superlite 831 FKBSS
Fleet of Canoes and one Kayak
So Many Rivers so Little Time!
buckisland1950 is offline   Reply With Quote
Old 05-16-2011, 04:57 PM   #7
flyrotor's Avatar
I have a small combination tool set, includes metric and sae socket sets, screw drivers with multiple tips from square bits, phillips, strait and allen bits, I carry a 12 v test light and multiple fuses, pliers and a rubber mallet. Don't forget the lug wrench and bottle jack. I have a star lug wrench with multiple size sockets on each star, and test it to be sure it fits your lugs. Most star lug wrenches will fit both your trailer and your truck, but don't count on your truck and trailer to have the same size lugs. I also carry a tire pressure gauge.
flyrotor is offline   Reply With Quote
Old 05-16-2011, 06:05 PM   #8
kmzad's Avatar
Better to have it and not need it than to need it and not have it.
kmzad
2011 Cherokee Grey Wolf 28BHKS (Melanie)
TV 2007 F150 5.4 L Tow Package
kmzad is offline   Reply With Quote
Old 05-16-2011, 06:06 PM   #9
(Kim)
Labzy's Avatar
......and that's all.........?
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
Old 05-16-2011, 07:45 PM   #10
The question about 'what's in your tool box' will get varied responses.. as varied as the individuals packing their RV's.
Seriously, I have a small cardboard box with some basic tools. A few fuses for the RV, some glue, a multi tool screwdriver, a crescent wrench, some pliers, some zip ties, some twine, electrical tape. (yadda yadda yadda)
Normally, I would carry some replacement light bulbs for the RV, but I want these to blow so they can be replaced with LED's.
One of the best investments I made was a 12 volt impact wrench. The first flat I had on my old Salem, the tire was on sand and there was no way to get enough torque on the lug nuts by hand to remove the wheel.... I pulled out the handy-dandy 12 volt impact wrench. It was slow in removing the lug nuts, but got the job done.
see you around the campfire
Darren
Old 05-17-2011, 07:11 PM   #11
sherdep's Avatar
I would rather be "Over Prepared" then "under prepared" besides if I could carry the Kitchen sink I would - cant carry it cause I have my hands full with all the other tools I carry
If you are looking for minimal to carry -
philips and flat head screw drivers,
small hammer,
channel lock pliers
small socket set,
extra bearing set with race and seal for the trailer - (saved me from being stuck)
Tire Gauge for air pressure
4 way bar - to get the lug nuts off
flat pieces (2 or 3) of 2x6 - (2 or 3 feet long)
a bottle jack
small package of fuses - (blade type)
There is probably more but if I had to have a minimal to carry that would be it.
Old 05-17-2011, 08:10 PM   #12
flyrotor's Avatar
oh, almost forgot, 2 permanent mounted beer bottle openers, one inside, one outside, they never get left behind, no matter how many bottles have been opened
Old 05-17-2011, 09:42 PM   #13
[QUOTE= beer[/QUOTE]
My kinda camping
A must have for any tool box.
Darren
Old 05-17-2011, 11:31 PM   #14
Herk7769's Avatar
they are nearly all #2 square bit.
HAM CALLSIGN - KC3FFW
