Hi toshiba. Our V lite leaked at the floor area also. I found 2 things. ONE was the portable shower (hand held) inadvertently got sprayed at an upward angle thereby running water down the outside shower wall; and TWO- the shower door has a channel along the bottom to divert water to either side, but it also makes a very un-useful gutter, that runs water out right at the side opening area of the door. Also this same channel holds water in it and when you open the door, it runs out on the floor. BAD DESIGN!! Thanks, and good luck, Randy
