Old 10-05-2013, 07:26 AM   #1
Leaking shower drain connections in 2013 832IKBS
On the front of our shower is a small access panel to the area below the shower. I removed this and found the drain line connections were loose and had been dripping water. The main flooring is cut away just below the drain to allow room for the U-trap. The cutaway goes all the way through the insulation to the plywood sub-floor. The damage didn't seem very extensive so I poured some water absorbent down there for a couple of weeks and it seems to have dried things out.
I also checked all of the connections in the bathroom and kitchen sinks and found i could tighten them a little more. Good things to check before you put the trailer away for the winter.
wilsonseattle is offline   Reply With Quote
Old 10-16-2013, 09:32 PM   #2
Hi,
Been off the forums for a while.
Just checked ours and it is dry. But, very surprised how little support is under the shower floor. It seems to do the job, but you can feel the floor flex a touch when stepping in certain spots.
2014 Flagstaff 832IKBS Travel Trailer
2012 F150 EcoBoost (HD Payload & Max Tow)
Doering is offline   Reply With Quote
Old 10-17-2013, 05:45 AM   #3
Same happens in my shower. There is a "soft spot" between the drain hole and the tub side just below the doorway. I figure that there must be no support in that area. One of these days I intend to open the panel mentioned and see if any support can be erected there.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Edition | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra SLE 5.3L | K&N filter | Hypertech Max Energy tune | Prodigy P3
Wmoses is offline   Reply With Quote
Old 10-17-2013, 01:21 PM   #4
Owner/Operator
RodeoGeorge's Avatar
Does anyone have a picture of this panel that they are referring to?
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 10-17-2013, 01:29 PM   #5
5 hole's Avatar
use expanding spray foam to 'firm up' the show floor from below. What they use in residential construction to set a tub.
5 hole is offline   Reply With Quote
Old 10-17-2013, 01:34 PM   #6
RodeoGeorge
At work right now. Will take a photo tonight.
It is a plastic panel on the shower base immediately beneath the shower door. You step up over the panel door when entering the shower. It is roughly 8" by 6" in size and secured with 4 screws on the corners.
Old 10-17-2013, 01:54 PM   #7
statgeek's Avatar
Similar problem happened for us with our last RV--a 2013 Coachmen Mirada 34bh, and also for a friend of ours who had the same coach. Since my rv was still under warranty, I had the dealer fix it. Their solution was a bead of silicone around the joint... not something that I would have done (seems like a band aid instead of a cure), but it did stop the leak, and I didn't have to soak up water with a towel after our showers...
statgeek is offline   Reply With Quote
Old 10-17-2013, 04:51 PM   #8
RodeoGeorge
This is the access panel to service the plumbing beneath the shower floor.
Name:	Shower access.jpg
2013, drain, leak, show, shower
