Old 09-23-2014, 02:22 PM   #1
Leaking slide outs
I have a 832IKBS TT 2014 that the two back slides leak while towing it in the rain. Anyone else have this prob?
Jonboyrutledge is offline   Reply With Quote
Old 09-23-2014, 04:22 PM   #2
offroad's Avatar
Our 8329SS (Rockwood clone of your 832IKBS) hasn't leaked in the rain but we also haven't towed it while raining.
I would think its a problem with the seals between the side of the camper and the flange on the slide. Probably along the front edge but could be along the top or where the two meet as well.
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 09-23-2014, 05:02 PM   #3
Ur prob right on that. Thnx.
Old 09-23-2014, 07:17 PM   #4
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
With the slides closed, look at the front and rear bottom corners of each slide and see if you can see day light. We had this problem (was also a sure entrance for mice) and took it in for warranty work. The dealer built up the corners with blocks of wood and fitted rubber strips around the edges to seal them. The water that got inside because of this problem was quite significant and took some time to completely dry out.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 09-23-2014, 07:21 PM   #5
Ur correct on seeing daylight in the bottom corners of the slides. I will call my dealer tomorrow. Thnx.
Old 09-23-2014, 07:25 PM   #6
Lloydg's Avatar
Post how it goes. I'd be interested in knowing how your dealer fixes it.
Old 09-23-2014, 07:26 PM   #7
U got it.
leak, slide, slide out
