10-30-2015, 02:24 PM
Left propane tank will not switch over!
I am having a meltdown here...my left propane tank will not switch over when turning the manual lever.I had everything apart and checked for obstructions and still will not work,took the hoses off as well and they seemed fine,18 p.s.i reg.on the left side seemed fine as well.Anyone had this issue?
10-30-2015, 03:16 PM
I had a switchover regulator once that wouldn't switch tanks either manually or automatically. Finally replaced it and all was well again.
There's also a set procedure for some regulators to get them to switch over.
Do you have a make and model of the regulator?
Gotta go campin!
10-31-2015, 06:18 AM
Thanks Bama..it is a Fairview gr-9984,i did hook up an air supply to the left side propane line and was able to get it to change over...wondering if the problem is with the red 18 p.s.i reg. on the left side!
10-31-2015, 06:05 PM
It sounds like it if it'll switch with air pressure.
Gotta go campin!
10-31-2015, 06:13 PM
Swap the hoses around between tanks!!
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
11-01-2015, 07:26 AM
I will try that today Rick...thanks!
11-01-2015, 10:28 AM
Switched the pig tails and that didn't work either ,back to the drawing board I guess,or just move the tanks around when needed!
11-01-2015, 11:34 AM
Recently new!
Change over
Just a thought. Verify that your hoses are clear. Are you sure that your left tank will pressurize the system?
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
11-01-2015, 12:31 PM
Fairview reg
Had the same problem with our 2015 Flaffstaff 8528RKWS. What I found was that on the Fairview regulator there are two brass couplings that are actually check valves. they are located one on each side of the crossover Fairview valve. Inside the brass check valves there is a spring and black plastic disk. In one of mine the disk was stuck and it would not allow gas to pass through. The brass coupling is known as a "Inverted Flare to MPT Connector" 1/4 Inverted Flare X 1/4 MPT. Part number 07-30045 JR Products, www.jrproducts.net . I replaced the bad coupling and all was well. Good luck
11-01-2015, 03:36 PM
When you had it off did you run a brush through it bc its possible that you have a cob web in it and they are hard to see.That,s what happen to me with my hot water tank.I took it apart and look thru it and didn't see it but ran a brush thru and seen it put it back together and it work
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
11-01-2015, 05:07 PM
Had the problem w/our 5W, not even a tear old. Tested it, gas propane was there (opened valve slightly to see it escape), other side worked fine, dropped tank on end (sometimes they stick), etc. Bottom line, bad regulator, but had to take 5W in to get warranty fix.
DrippingDuo
Chappy and Liz
Dripping Springs, TX
11-01-2015, 05:47 PM
mine does not have the couplings,i think they are incorporated in the hose,but thans anyway!
11-01-2015, 05:49 PM
Did they replace the red regulator on the left or the switchover reg.on the right side?
11-01-2015, 07:55 PM
I have the same problem with my 8528RKWS. Mine won't switch from the street side to curb side tank. I'll try these solutions. Thanks everyone for the suggestions.
11-01-2015, 08:37 PM
Had a blocked hose going from Driver side to passenger side of the 5th wheel.... changed everything except that hose
Anders Campbell River,
BC. Canada
Pony: 2017 Dodge 3500 Longhorn 4x4, Quad Cab Chuckwagon: 2020 GD Solitude 310 GK
My RV Cookbook now on Amazon! USA or Canada
Travel Blog
Cooking Blog
11-04-2015, 08:08 AM
Propane won,t switch over from left to right ?
I am starting to believe I have a hose issue as well, I took them all off,even the long one running through the 2 inch tube and I am thinking that the safety valve inside is malfunctioning!It takes too much air pressure to make the green indicator go on.
11-04-2015, 10:21 AM
How much pressure does it take?
Gotta go campin!
11-05-2015, 09:46 AM
I am guessing but at least 35-45 p.s.i
11-05-2015, 09:58 AM
Just for giggles. Turn off left tank. Disconnect it from regulator. Reconnect it and slowly turn on propane. It is possible that the safety mechanism in the left tank has been activated and shut off the propane, this makes the tank appear empty to the regulator and it will not switch.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
11-06-2015, 07:31 AM
Thanks Bob...I did that as well !
