Old 06-04-2018, 02:05 PM   #1
Mama's Avatar
Leveling/Stabilization
What set up should we get to make leveling/stabilizing our new Flagstaff MicroLite-21FBRS? Is there something that does both?
Mama is offline   Reply With Quote
Old 06-04-2018, 02:10 PM   #2
Fulltime family RVer
Short of an automatic leveling system like the Lippert LevelUp, you need 2 different products for leveling vs. stabilization.
Leveling is done by raising one side of the camper by putting something under the wheels:
http://learntorv.com/rv-leveling-is-...uick-and-easy/
I like LynxLevelers:
LynxLevelers Leveling Blocks | Learn To RV
Stablizing is a never ending quest depending on how stable you want it:
Shake, shake, shake – RV Stabilization | Learn To RV
I like the SteadyFast system:
Product Review: SteadyFast Stabilizers | Learn To RV
ependydad is online now   Reply With Quote
Old 08-01-2018, 09:53 AM   #3
For stabilization we use BAL X-Chocks, trailer is rock solid when they are on. For leveling I go with two boards, one 2 inches and the other is 1 inch, cheap and simple.
Kevin
2009 F150 XLT crewcab 5.4L and 3.73
2010 Flagstaff 27 BHSS
tenttotrailer is offline   Reply With Quote
Old 08-11-2018, 08:52 AM   #4
I believe andersen makes them, but there are levelers that are shaped like teardrops.. put them under the low side and the further you pull forward, the higher it goes. X chocks work great for stabilizing.. and there is also a device i used to use called levelmatepro.. those things made leveling a 2 minute process
2018 Flagstaff 831BHWSS
Custom Yukon XL 2500 Duramax conversion. Tuned, deleted, and other goodies
n0useforaname is offline   Reply With Quote
Old 08-11-2018, 09:51 AM   #5
Camco now makes them as well for those of us with tires closer together. We’ve had both and both are good. Used with the LevelMate Pro and leveling is a breeze.
ImTravis is offline   Reply With Quote
Old 08-11-2018, 10:26 AM   #6
Oaklevel's Avatar
Depending on your buget.
Our 35 year way of doing things.........
Cheapest way for leveling use 2x8s under the tires. For stabilizing, the stabilizing jacks usually are on the trailer from the factory (not always)................ then add X chocks or similar (dual axles). I am still planning on a JT strong arm attachment or similar for stabilizing as well. Would like to get them and install them this fall.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-11-2018, 10:32 AM   #7
I've used both the camco levaling blocks, that are similar to the Lynx levelers, and I now use the andersen leveling kit and regular wheel chocks along with my stabilizer jacks to stabilize. I should have ponied up for the andersen kit a long time ago. Not cheap but man does it make leveling a breeze...
poriggity is offline   Reply With Quote
Old 08-11-2018, 11:53 AM   #8
Don't think so.
When we started out, we leveled with boards. Now we use the Lynx leveling blocks with the Lynx chocks that allow one person to handle the MH. Their chocks will stop the vehicle when it contacts them. No more 'falling off' the levelers.
As recommended, the xchocks will help the back and forth motion of the trailer when you're camped. Nothing works perfectly because you're on wheels.
Looks like a great rig.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
leveling
