Old 08-15-2017, 11:17 AM   #1
Leveling with a slide out
We recently traded in our microlite 23lb and purchased a microlite 25brds that has a slide out. When leveling should the camper be level before or after the slide out is out. Just something I thought about. I backed into the site this week and was level side to side then I happened to notice the level after we were all set up and we weren't level side to side anymore. Then it hit me the weight of the slide out did it. So what is the consensus, do I allow for the weight and keep the side with the slide high or park it level and not worry about it. Never had a slide out before so it is all new to me.
mjp1056 is offline   Reply With Quote
Old 08-15-2017, 11:25 AM   #2
We know that on a Level site before deploying the slide that the "Slide Side" needs to be 2" Higher! Yours may differ! Youroo!!
Old 08-15-2017, 11:26 AM   #3
We have found that starting with the slide side high about 1 block, it comes level after a little time with the slides out.
KKonyha is offline   Reply With Quote
Old 08-15-2017, 11:31 AM   #4
Mine changes about an 3/4 inch (side to side) with the slides out.
We compensate for that when leveling upon arrival.
I actually installed a second level that that indicates what level will be once the slides are deployed.
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 08-15-2017, 11:36 AM   #5
Dave Lyon's Avatar
I level the trailer side-to-side then front-to-back with the slide in. I then put down the stabilizers and put the slide out.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 08-15-2017, 12:38 PM   #6
Slide / Leveling
On my 32' Wildwood, I have found that extension of the slide results in a one mark drop in the "bubble level". As a result, I always "level" the trailer with the bubble one mark high on the slide side. I NEVER extend the slide until the trailer is level as described, and the stabilizer jacks are down and secure.
JimMorrell is offline   Reply With Quote
Old 08-15-2017, 12:48 PM   #7
We have 2 slides on the ODS side of our trailer. We also find that if that side is about 1 inch higher than level that we end up about level after both slides are out. We then put the stabilizer jacks down.
John, Betty and Andy & Ian
2013 Toyota Tundra Double Cab 5.7L 4x4
2013 Flagstaff Classic Lite 831FLSS
jafud1 is offline   Reply With Quote
Old 08-15-2017, 01:43 PM   #8
Was
Like many others have said, I know my slide out will bring it's side down about 3/4 inch, so I make it 3/4 inch high when leveling, then extend slide.
Was is offline   Reply With Quote
Old 08-15-2017, 01:44 PM   #9
Canadian Member
X2
Our travel trailer has a single super slide, about 16' long. I use a 2' long carpenters level on the floor of the trailer for levelling side-to-side. I know that the slide will affect the side-to-side level slightly but I've never measured it. I will leave the slide side a bit high if it works out that way but I don't work at getting it that way before extending the slide. As long as the level's bubble is at least 95% in the middle and it's not low on the slide side, I put the slide out.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 08-15-2017, 02:08 PM   #10
Jesse's Avatar
Level with slides
We always level with slides in, as per manufacturer instructions from dealer. Slides are meant to carry their own weight and should not even use slide supports, they can mess up gearing in slides and slide unit will not seal properly to main body, per dealer.
Jesse
2016 F450
2017 Cedar Creek 38EL Champagne
Only here once - do it baby!
Jesse is offline   Reply With Quote
Old 08-15-2017, 02:29 PM   #11
Kasual Kamper
+1 I believe that this is what the manufacturer instructions recommend. You can then make adjustments after the slide is out if you have to so that your refrigerator stays level.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is online now   Reply With Quote
Old 08-15-2017, 02:57 PM   #12
510Rick's Avatar
How would one go about making a level adjustment once a trailer is unhooked and the stabilizers are down ? Our trailer has stabilizers and not levelers .
TV:GMC 2500HD Duramax
TT: 2015 Wildwood 21rbs
510Rick is offline   Reply With Quote
Old 08-15-2017, 03:09 PM   #13
Kasual Kamper
Adjustments are generally minor, so tweaking the stabilizers a little tighter on one side and releasing tension on the other is all that is usually required.
Old 08-15-2017, 03:45 PM   #14
Tabasco's Avatar
You'll soon learn your RV leveling system thru experience as I did...after reading all the replies I see every RV is a bit different...the short answer is you'll need to learn exactly where your bubble needs to be before the slide comes out! Just remember you're RVing for a reason...Have fun and don't get stressed out over it!
2015 Toyota Tundra 4x4 TRD with 5.7L
2016 Forest River 27RKSS 30ft.
Tabasco is offline   Reply With Quote
Old 08-15-2017, 03:54 PM   #15
510Rick's Avatar
I dont understand how to do that with these stupid lippert electric jacks . If one side touches something the other side then goes down .
Old 08-15-2017, 04:22 PM   #16
Carknocker Family
Ida Ratherbe Camping's Avatar
They may not have same stabilizer as you and I. Sounds like they may have the manuel screw stabilizer.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 08-15-2017, 06:34 PM   #17
dmdomokos's Avatar
After unhooking, I may notice I didn't quite get the slide side high enough. So I will put down only the two stabilizers on the slide side as much as they will go (without popping a breaker), put the slide out, then put down the opposite side stabilizers. That seems to give me a little more height on the slide side. Then after a day, I will tighten the stabilizers on the slide side first.
2016 Rockwood 2702WS
2016 Chevy 2500HD Duramax 4x4 High Country
dmdomokos is offline   Reply With Quote
Old 08-15-2017, 06:53 PM   #18
crunchman12001's Avatar
Slide side high...
You will get the feel for how high after you un-hitch, deploy stabilizers and run slide out.
My old rig was 1/2 bubble off before slide deployment on a 12" torpedo level.
2015 F-250 FX4
Old 08-15-2017, 10:00 PM   #19
rockfossilman's Avatar
X2 + we found out that the most important thing to be level is the frig--our TT has to sit slightly out of level for the frig to operate properly.
Rockfossilman - Western PA
Rockwood UL 2604ws - 2013 F150 w/MaxTow
"I'm a man, but I can change, if I have to. . .I guess."
Red Green
"Quando Omni Flunkus Moritati"
rockfossilman is offline   Reply With Quote
Old 08-15-2017, 10:07 PM   #20
david_reaves's Avatar
My Windjammer has stabilizers that are connected on a single screw rod. They hold minimal weight and do not lift at all. I use two Anderson roll-on levelers on the slide-out side to raise the driver side of the trailer about two inches on an otherwise level site. That varies if the site itself isn't level. Once I'm on the leveler blocks, then I put the stabilizers down and the slides out. The torque on the trailer from the weight of the slides drops me into perfect side-to-side level.
david_reaves is offline   Reply With Quote
leveling, slide, slide out
