Old 04-17-2018, 07:58 PM   #1
Linoleum floor
I have a spot about a foot round in my floor and is not glued down becoming a bubble what do I do. Is there something I can do or do I need to bring it back to the dealer.
dave g is offline   Reply With Quote
Old 04-18-2018, 07:11 AM   #2
Short of injecting the 'bubble' with glue, it will need repaired by replacing.
Keep in mind the linoleum is the first thing glued to the the subfloor and EVERYTHING is built on top of it. Unless a piece could be spliced in somewhere, the entire unit would need disassembled. (walls removed etc.)
I don't see that you have a signature line indicating what your your unit is.
If under warranty, see your dealer.
Days Camped: '17=30 '18=51 '19=58 '20=21
Old 04-18-2018, 02:00 PM   #3
Hi I have 8528 IKWS. Diamond series
Old 04-18-2018, 02:08 PM   #4
Are you sure it is just a linoleum issue?
Many of these units (before 2017) have a composite 'sandwich' floor. (styrofoam sandwiched between two pieces of thin luan/wood) The floor develops a 'soft spot' (compresses the styrofoam) and the linoleum comes loose.
floor
