Old 10-08-2017, 04:33 PM   #1
Lippert Rear Stabalizer
Just finished winterizing and went to retract the rear stabalizer (Lippert). Nothing happens, no noise either. I hit the extend button and that works though. Did it for a quick second as a test only, since that is not the direction I need.
This is on my Flagstaff 28BH 5th wheel. Any suggestions to troubleshoot. Also, if I can’t get it, is it ok to leave through winter or should they not be extended during the winter? I don’t want to make it a more severe issue come spring.
Thanks for any advice provided!
BajaX is offline   Reply With Quote
Old 10-09-2017, 09:23 AM   #2
Have you done any electrical testing at the switch?
Often times if the jacks go one direction and not another there could be switch/wiring connection issues.
Do you have a multimeter/test light and know how to use them?
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 10-09-2017, 09:44 AM   #3
No electrical testing whatsoever. It was actually raining pretty hard at the time, so I left it as is for now and will return in a few days to troubleshoot.
I have both testers and will add to my to do list.
I posted in hopes that I will get many pieces of advice. Armed with the right info, will make my troubleshooting more efficient.
Old 10-09-2017, 09:52 AM   #4
Nelsflying's Avatar
My Lippert rear stabilizer did the same thing, turned out to be disconnected wire on the back of the switch.
Nelsflying is offline   Reply With Quote
Old 10-09-2017, 09:55 AM   #5
I’m hoping it will be that simple. I’ll put the switch on the top of my list.
Old 10-13-2017, 12:05 PM   #6
It turned out to be the switch. It wasn’t disconnected but severely impinged by a poorly drilled hole. I shaved the opening, reset the switch and everything worked as expected.
Thank you!
