Old 03-22-2016, 03:13 PM   #11
Kaadk's Avatar
Originally Posted by Hef View Post
I only need the table. anyone ever order one?
I had tried. The price the dealer wanted to order me one is why I went with the "build your own" approach.
If I understood your question, you have 1 table already and want a second to get more space right? So, either see what the dealer says it'll cost you to get one, or turn the one you have into a single bigger table. Just need to unscrew the hardware from the existing one, and then screw it onto the bigger one.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 03-22-2016, 03:15 PM   #12
Hef
Hef's Avatar
Called FR and the table is $55.00 plus $20.00 to ship. No thanks i'll find a better option.
Hef is offline   Reply With Quote
Old 03-24-2016, 09:42 AM   #13
beagle22b07's Avatar
Table Plans
Originally Posted by kraftengr View Post
I made my own table for beside the track stove. I wouldn't camp without it! I made it for our Popup but it can work on any track. Tracks are easily purchase on line and are inexpensive.
Kraftengr - I really like your table. Would you be willing to share how you made it? What is the size of the top and what is it made of? What sizes of pvc pipe did you use? This is a nice mod. Thanks
Larry
Larry & Chris (Abbey & Brody camping cats)
2016 Ford F-150 XLT Sport, Super Cab, 3.5 EcoBoost, 3.55, 4x4, MaxTow w/36 gal fuel tank
2015 Rockwood MiniLite 2104S, EMS-30HW, Carchet TPMS
Days Camped: 2015 = 51; 2016 = 59; 2017 = 20
If you're lucky enough to be camping......You're lucky enough.
beagle22b07 is offline   Reply With Quote
Old 03-24-2016, 09:59 AM   #14
Thanks Larry!
The table top is actually a 2' x 4' sheet of masonite (that has one side finished as a wipe-off marker board) that I got a Lowes. To that I added a 1/4 plywood backing and 1 x 2 support frame for support.
The legs are PVC pipe that I also got at Lowes with the outer pipe being 1-1/2" (as I recall). I actually went to the store and tried various sizes to see which size would fit inside the next larger size with the least play. The problem you have is that the ground at the level where the legs hit the ground is never at the same distance below the table level. By drilling holes in the outer pipe at 3-1/2" ctrs and holes in the inner pipe at 1" ctrs over an 8" distance, the adjustment range becomes approximately 16 inches which has been more than enough. In that combination of holes, the legs are adjustable in 1/2" increments.
Hope that helps! Gary
kraftengr is offline   Reply With Quote
Old 03-26-2016, 12:11 PM   #15
I havent, but sure have thought about it. Please keep me posted on where you got it and how much it costs.
My next TT project is replacing that horrible blue LED in the fridge. Just got the white one delivered from Dometic.
Ranger431 is offline   Reply With Quote
Old 03-26-2016, 05:28 PM   #16
Thanks Larry!
Thanks Gary, that's what I need for a start.
Larry
Old 03-26-2016, 07:42 PM   #17
Nevermind, missed the post above. Wouldn't mind another one, but $75 is pretty steep.
flagstaff, slide, slide out
