I have a 2018 Flagstaff Micro-Lite 25BDS that is equipped with a single slide-out. The slide has a u-shaped dinette inside.
When I took delivery the tech handed me a "wrench" much like the one used for the stabilizer jacks (only smaller socket) and said "this is so you can retract the slide if the electrical system fails".
OK, seemed simple except he didn't show me how. I went to the owners manual and it merely tells me to lift a piece of carpet and engage the nut on the gearbox (or some such).
I contacted Forest River and received a prompt reply with a PDF describing the twin motor Schwintek slide. Looks nothing like mine.
Mine has a single tubular motor mounted next to the "rack" of the rack and pinion slide actuator. One motor and the front and rear are kept in sync by a pair of pinion gears mounted on a shaft that engage a rack at the front and rear of the slide. Again, only one motor.
I have looked high and low for any way to access the end of the drive motor that pushes the slide in or out. No visible access. The only thing I haven't done yet is to pull down the underbelly cover.
Does anyone else have this similar setup and knows how to operate the slide if the power system fails?
Front with motor:
Pinion shaft and front rack:
Motor:
This is my first trailer with a slide. My last trailer lasted me 22 years and a lot of miles. I kind of like to get my money's worth. This puzzles me and I'm not too proud to ask for instructions. Please don't take away my "man card" because I have
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
